Garage clean out ej205 parts
Discussion in 'For Sale : Car Parts' started by Casey, Mar 30, 2016.
  1. Casey
    Casey Member
    heads are sold
  2. Casey
    Casey Member
    Sti manifold, wagon tail light, center dash piece, washer fluid res and 16" Wrx wheel all gone
  3. Casey
    Casey Member
    Updating the main post constantly.
    Long story short, sold my two bug eyes and have parts to clear out as well, most parts are best offer, not in a rush just trying to recoup the money.
    I have a full sedan suspension conversion for my old wagon, cross member, lca's, rack and pinion, 20mm sway bar... Rear lateral links and all four axles in decent shape. $350
    Front and rear stock sway bars off my 02 wagon. $40
    04 Sti wiper motor/transmission assembly $40
    Ej205 running short block I bought off of a member claimed 130psi across the board sitting on an engine stand since I got it. Rotating assembly, oil pick up and oil pan $425
    Mitsuboshi timing belt and also oem gasket full ej205 set bnib $360 firm
    Resurfaced flywheel from machine shop ej205 5 speed $100
    2013 Sti injectors 23k on them$150
    05 sti 20mm front and rear sway bars with bushings $80
    Passenger side front door card with a couple small tears, $5
    Stock shifter and linkages from my 02 Wrx $20
    02-03 sedan front struts and all four springs, took off because I had a set of tein lowering springs that I thought would be lower and weren't, cannot read what's on it, $40
    Crappy dual 12" bandbass box $10
    04 WRX Trunk with Stock wing JBP no dents paint is in good shape, $250
    Catless up pipe off my Sti $50
    Tactrix 2.0 with cable $100
    SOLD ITEMS
    Perrin lightweight crank pulley$ SOLD
    Auto dimming mirror $SOLD
    White line front strut tower bar 02-07 SOLD
    05 Sti obp rear trunk with wing and wiring in great shape $SOLD
    Stock Wrx floor mats that are in okay shape? $SOLD
    Saggy butt spacers with top hats already mounted with the longer bolts installed for 1/2" lift. $Sold
    02-07 Wrx 3" tbe and up pipe brand new no name exhaust $SOLD
    Kart boy shift knob for a non Sti in great shape $Sold
    Vf34 sold
    Ej205 heads fresh from the machine shop with papers of what was done, still oil'd in the bags will come with half moons, cam gears, valve covers $SOLD
    I'll keep adding to it as I find stuff BEST WAY TO REACH ME shoot me a text for questions 9529929688 thanks
    PICTURES HERE http://imgur.com/a/g29UN
  4. tangledupinblu
    Interested in a winless trunk mang? :)
  5. Casey
    Casey Member
    Not really anymore, got a cf one now. What da got? Shoot me a text
  6. Casey
    Casey Member
    I have a full sedan suspension conversion for my old wagon, cross member, lca's, rack and pinion, 20mm sway bar... Rear lateral links and all four axles in decent shape. $300
    Front and rear stock sway bars off my 02 wagon. $20
    04 Sti wiper motor/transmission assembly $25
    Ej205 running short block I bought off of a member 130psi across the board sitting on an engine stand since I got it. Rotating assembly, oil pick up and oil pan $375
    Mitsuboshi timing belt and also oem gasket full ej205 set bnib $340 firm
    Resurfaced flywheel from machine shop ej205 5 speed $80
    05 sti 20mm front and rear sway bars with bushings $60
    Crappy dual 12" bandbass box $free
    04 WRX Trunk with Stock wing JBP no dents paint is in good shape, $200
  7. Casey
    Casey Member
    Updated prices
  8. Casey
    Casey Member
    tactrix sold, sti sway bars sold
  9. Casey
    Casey Member
    I have a full sedan suspension conversion for my old wagon, cross member, lca's, rack and pinion, 20mm sway bar... Rear lateral links and all four axles in decent shape. $200
    Ej205 running short block I bought off of a member 130psi across the board sitting on an engine stand since I got it. Rotating assembly, oil pick up and oil pan $370
    Mitsuboshi timing belt and also oem gasket full ej205 set bnib $320 firm
    2013 Sti injectors 23k on them$140
    Stock wagon springs 02-03 $20
    02-03 radiator $20
    02-03 drivers side WRB WRX side skirt $20
  10. Casey
    Casey Member
    Flywheel, shortblock and springs sold
  11. kondan
    kondan Active Member
    Damn, needed that ej205 shortblock!
