Gauges
Discussion in 'Modifications And Maintenance' started by Tash, Nov 2, 2010.
  1. Tash
    Tash Well-Known Member
    just trying to get some info, im shopping for gauges to fill my new triple gauge pod. just wondering what brand/model gauges everyone is running and how they like them.
  2. ofspunk7
    I am not running, but going to pick up some PLX gauges this winter and install in spring.
    http://www.plxdevices.com/multigauges.html
    You have to buy each sensor for each gauge.... but you an insane amount of options for display and what you want to monitor..... check out the vids on the website.
  3. stoooo
    stoooo Well-Known Member
    I like my STRIs. They work, and were very reasonably priced. Don't fret, they do come in colours that are a match to the USDM dash cluster.
    (The picture was taken before all the wiring was finished. Rest assured, they all work as advertised.)
    Stuart.
  4. ofspunk7
    I love that ABBA is playing on your CD Player!
  5. yamie700
    yamie700 Well-Known Member
    If you like digital gauges check out VEI. They have led's around the edge so its sort of like analog also. I've had boost and oil pressure gauges in my LGT for about 5 years, no problems.
    http://www.veisystems.com/products.html
  6. stoooo
    Get with the times; it's coming off the USB memory stick :D
  7. Bielke55
    I'm very je-laus of your gauges
  8. TheSnowman
    TheSnowman Well-Known Member
    i going to be getting some today, i was going to go with prosport. i have heard good things about them.
  9. Tash
    i was looking at the prosport ones too, i like the way they look but seems like gauge selection is limited
  10. stoooo
    I seem to remember when I was shopping around that people said the Prosports were good. As long as the range includes the ones you want/need, then 'limited' is a relative term. What info are you looking to get from your gauges ? Metric or Imperial measurements ? What diameter are the holes in your pod ? These are all details which might help us to help you.
    For me, I knew what gauges I wanted and in what units, and I knew that I needed ones that matched the OEM dash colours. Then it was a matter of looking around for the manufacturers that met those criteria. No matter how cheap, or how impressive a gauge set was, if it didn't satisfy those two needs, it was cut from the list. That made my short list very short indeed.
    Oh, and keep in mind that a lot of dealers right now are willing to haggle. Times are tough, and they want to get those sales closed. So if you find something that fits the bill but is otherwise a bit out of budget, don't write it off until you've checked in with at least a couple of dealers and tried to talk them down. It never hurts to ask.
    Stuart.
  11. ofspunk7
    I would talk to import image about prosport gauges. He told me that they would be able to swing a good deal, better than any other prices I was finding online.
  12. Bullwinkle
  13. Tash
    ok so im looking for green (to match the gauge cluster) and i need to find 52MM. as for measurments i dont care that much cuz i can read them all.
