Got Problems....
Discussion in 'Modifications And Maintenance' started by putz, Aug 11, 2008.
  1. putz
    putz Well-Known Member
    Driving to bir yesterday, I every thing was fine, the car felt amazing, when...
    I pulled over for gas in baxter checked my oil, level was perfect. (hard to tell on our stupid dipsticks)
    I start going again up HWY371 and I get up to 65 mph and I let off the gas and I hear a sound comming from the pass. side of the engine bay, right from the turbo, I think my downpipe cracked or I crack my o2 bung on the bellmouth... the car only makes this noise under accelleration and at on start up.
    I frustrated....:roll::roll::roll:
  2. gc8
    gc8 Well-Known Member
    What sort of sound...?
  3. putz
    sounds like an exhaust leak wistling througha multi layer exaust gasket????
    Maybe had a bolt rubbing on a exhaust housing cause I stupid and used the wrong length bolt?????
    I have to take the dp off tonight so I can see if the dp is craked.... I wrapped the piss out of the pipe, the exhaust housing, and the up pipe so I can't see if it is cracked...
  4. curly2k3
    could be a crack or a leak... maybe if you did all the deletes and a K&N and stuff thats what you are hearing?
  5. Paul Revere
    Isn't all your stuff wrapped?
  6. putz
    leak part... pretty sure...
    other stuff, not so much. I've been riding around like this for 2 weeks now.... and this sound is new as of yester day...
    I think I may order a down pipe tomorrow we'll see what I find tonight.:emo::emo:
  7. putz
    yeah... it is. so it maybe hard to find any cracks.... this sucks:emo::emo::emo: so bad.
  8. putz
    took the down pipe off, the turbo seems fine, down pip has no cracks, did notice sone carbon across the gasket face, looks like I did have a small exhaust leak.
    now, I have got a adjustable turbosmart dual port bov, I beleave it may have been adjusted past the "STOP!!! DON'T ADJUST PAST THIS HERE OR YOU MIGHT BLOW STUFF UP" line....
    (i feel like such a bone head) I'm going to go back and check for boost leaks tonight...
    do you think I can reuse my gasket to put the down pipe back on with?
    I know you have thought this so I'll say it....
    HEY, Putz.... put the stock bpv back on.....
  9. Bielke55
    Dont reuse exhaust gaskets... They have a greater chance of leaking since most of them are a crush sort of gasket.
  10. putz
    okay. I'll go get a new one
  11. putz
    opinions on RTV silicone for BOV Gasket?
  12. Impreza 2.2 T AWD
    Impreza 2.2 T AWD New Member
    uhhh, i have a different engine but;
    I noticed a hissing sound from my car not to long ago, I just have to adjust the air conditioning vent to bi level and the sound goes away. Probably not the issue but that was my first thought.:)
  13. putz
    it was the bung on the up pipe, the plug backed out.....
  14. Scuba Steve
    got your message....I'm so happy it was something easy. i can't remember what the size is....like 12/1.25 bolt that will fit in there
  15. putz
    it looks like most egt sensors are 1/8" npt...
    but that was deisel.
