Grind down shifting to 4th
Discussion in 'Modifications And Maintenance' started by JasonoJordan, Sep 11, 2010.
  1. JasonoJordan
    Model: 02 WRX
    Mileage: Apx. 100k on transmission
    Mods: LW flywheel act flywheel, act street HD pressure plate and clutch disk, 02 WRX auto drive shaft and r180 rear diff.
    This happens regardless of speed it seems to happen less when the fluid is a little colder. Brand new up to lvl xtra s is in the transmission. It only happens on down-shift even if its rev matched and double clutched. Im thinking possibly syncros but it seemed weird that it didn't do it shifting up. Any thoughts on the matter
  2. dustin8511
    dustin8511 Member
    i thought you had a 6spd?
  3. JasonoJordan
    I do.
    Sent from my Droid using Tapatalk
