GT3076 airboy roaddyno 24psi...E85
Discussion in 'Modifications And Maintenance' started by Tdagen, Oct 31, 2009.
  1. Tdagen
    Tdagen Well-Known Member
    AnDoVeR, MN- Playin with moonshine...
    Here it is
    2002 bugeye
    2.5L hybrid w 9.5:1
    07 6mt (log done in 3rd)
    Custom fabbed T3 3076 .82
    Avo Tmic
    Bosch 044 fed by intank walbro 255
    T1 ID bosch 1000cc @ 70psi base about 1200cc's
    Fuelab FPR
    Halman evo rx + GM bcs
    Romraider tuned by me
    Here it is I don't know how to scale it bigger so it goes right off the charts... holds 400whp to redline pretty much
    Here is an over lay of a run where it holds just a hair less boost...
    Let me know what you think....
  2. vangstaboi86
    Looks good travis
  3. Tdagen
    Thanks we have to get together man...
  4. john
    john Well-Known Member
    Hudson
    Damn nice numbers, but I think something is missing. My car (100% stock 2.5 litre longblock) made made right around 400 hp and 400 ft/lbs at 18psi worth of .82 A/R gt3076r & e85 with an AVO pump upgrade and 816cc injectors on a dyno dynamics rig & CF of 1.15.
    A few months later it made 435 awhp and 464 ft/lbs on a mustang dyno burning 91 octane with a few gallons of e85 blended in @ 23psi.
    What does your timing look like?
  5. vangstaboi86
    Yea we should man
  6. Nuke
    Saint Paul
    Yes, what is your timing like?
    Looks like you might be able to squeeze some ponies out of it.
  7. Tdagen
    I think this power is about right on, Vangstaboi made 445 whp on E85 at rs mustang dyno at high boost, what was his boost level? I will post some logs up that go with the dyno's.
  8. Nuke
    Saint Paul
    gauge says about 28ish, mustang dyno says about 26ish
    but his timing is pretty aggressive
  9. Tdagen
    Nice!! What is his timing like? I am going to post a log up with my total timing.
  10. Impreza 2.2 T AWD
    Impreza 2.2 T AWD New Member
    Avondale!!!
    nice..... I like how smooth the lines are.....are they crossing at 5252???? again good data!!!
  11. Tdagen
    Code:
    Tim	rpm	ITT	idc	psi	Toa	AFc
    2895	2883	19 	15.99	3.25 	100	0
    3039	2925	17.5	16.85	4.06 	100	0
    3183	3007	17.5	17.96	4.93 	100	0
    3334	3078	17 	19.04	5.88 	100	0
    3477	3159	16.5	20.89	7.04 	100	0
    3619	3244	16 	22.84	8.41 	100	0
    3764	3311	15.5	26.13	4.99 	100	0
    3903	3442	15 	30.84	12.07	100	0
    4048	3561	14.5	37.98	14.81	100	0
    4202	3664	15 	47.68	18.85	100	0
    4353	3838	15.5	58.95	23.65	100	0
    4496	4017	15.5	64.94	24.44	100	0
    4640	4188	16 	67.89	24.5 	100	0
    4786	4350	16.5	69.6 	24.5 	100	0
    4931	4518	16.5	72.28	24.44	100	0
    5073	4664	17 	72.63	24.4 	100	0
    5216	4842	17.5	73.34	24.21	100	0
    5359	5000	17.5	73.6 	24  	100	0
    5504	5154	18 	74.77	23.92	100	0
    5644	5300	16.5	75.75	24.02	100	0
    5787	5494	16.5	76.19	23.96	100	0
    5927	5626	17 	76.82	23.84	100	0
    6072	5832	17 	77.14	23.76	100	0
    6219	5882	17.5	76.54	23.82	100	0
    6359	5976	17.5	76.49	23.92	100	0
    6503	6168	17.5	77.63	24.07	100	0
    6641	6297	20 	77.91	24.13	100	0
    6783	6372	20 	77.48	24.21	100	0
    6925	6438	20.5	76.91	24.27	100	0
    7075	6550	21 	76.85	24.31	100	0
    7216	6708	21.5	77.28	24.34	100	0
    7361	6762	22 	76.46	24.29	100	0
    7501	6925	22.5	76.82	24.33	100	0
    Code:
    Time	rpm	Itt	Idc	psi	Toa      afc
    1013	2200	22.5	9.86	0.41	100	0
    1155	2263	20.5	10.14	0.64	100	0
    1297	2307	20	10.83	1.01	100	0
    1441	2359	20	11.07	1.35	100	0
    1590	2409	19	11.76	1.76	100	0
    1744	2460	17.5	13.12	2.17	100	0
    1889	2496	16.5	13.85	2.63	100	0
    2033	2581	16.5	14.31	3.07	100	0
    2176	2630	17.5	15.25	3.5	100	0
    2320	2695	17.5	15.52	3.94	100	0
    2464	2759	17	16.48	4.51	100	0
    2608	2812	17	16.8	5.09	100	0
    2763	2902	17	17.96	5.84	100	0
    2908	2994	16.5	19.16	6.59	100	0
    3050	3062	16.5	20.25	7.54	100	0
    3197	3156	15.5	22.22	8.55	100	0
    3345	3238	15	25.56	10.09	100	0
    3491	3383	15	28.2	11.89	100	0
    3632	3462	14.5	34.72	14.25	100	0
    3777	3599	15	43.76	17.81	100	0
    3920	3714	15.5	54.68	22.41	100	0
    4061	3842	15.5	62.29	24.31	100	0
    4201	4034	15.5	65.41	24.4	100	0
    4344	4208	16	67.11	24.46	100	0
    4488	4406	16.5	70.5	24.48	100	0
    4644	4548	17	71.8	24.46	100	0
    4794	4732	17	72.68	24.34	100	0
    4937	4886	17.5	72.96	24.17	100	0
    5082	5037	17.5	73.07	24	100	0
    5231	5194	18	74.24	23.96	100	0
    5376	5384	18.5	76.95	23.9	100	0
    5522	5605	19	76.53	23.88	100	0
    5666	5682	19	77.57	23.86	100	0
    5809	5882	19	77.8	23.84	100	0
    5950	5962	19.5	76.31	23.84	100	0
    6092	6082	19.5	77.86	24.02	100	0
    6232	6137	20	77.25	24	100	0
    6375	6340	22.5	77.09	24.15	100	0
    6518	6476	22.5	77.37	24.21	100	0
    6660	6573	21	77.12	24.25	100	0
    6800	6690	21.5	77.07	24.31	100	0
    6945	6756	22	77.83	24.34	100	0
    7089	6874	22.5	76.26	24.25	100	0
    Looks like the boost was pretty close on the two runs actually. Timing was a little low actually on the top end I am shooting for 24.5... Must be pulling a little timing, I am not using my SD rom/groupn that one wont pull ANY timing ...:eek3: I just gotta finish it up I have not been able to get much tuning in with all the rain we have been blessed with.
  12. Impreza 2.2 T AWD
    Avondale!!!
    wow.....
  13. Tdagen
    Thats a little better...
  14. Impreza 2.2 T AWD
    Avondale!!!
    yes, yes it is....thanks
  15. Tdagen
    I think at this point the TMIC is my first limiting factor , and the wrx heads/ camshafts are my next.... We will see whats next I am thinking a custom Garrett cored FMIC, then possibly Borg Warner 88-75 T4 TS....:yumyum:
  16. Impreza 2.2 T AWD
    Avondale!!!
    the front mount will help a lot but, be prepared for some lag....there are very few cars that use so much intercooler piping
  17. Tdagen
    Yeah that is one of our main problems, I have thought about a reversed intake mani with a v mount to keep IC piping way down.... But I don't know if it would be worthwhile...
  18. Impreza 2.2 T AWD
    Avondale!!!
    IMO it is but then the turbo should be mounted differently as well.... look into variable vane turbos....less lag and high boost!! like most quality things....$$$$$$
  19. Nuke
    Saint Paul
    Let's just say, his pump timing looked just like your e85 timing...hehehe
  20. Tdagen
    Nice!;) Yeah that car does have one hell of a powerband, what were you guys reving it out to again?
  21. Nuke
    Saint Paul
    7600
    He has short gearings
