halp, i keep losing exhaust bolts/nuts
Discussion in 'Modifications And Maintenance' started by derp, Mar 8, 2012.
  1. derp
    Recently I installed an Invidia downpipe, and now I keep having issues with it.
    I've lost 4 nuts from the turbo to the downpipe, and no matter how much I tighten them, they keep loosening or falling off.
    Do I need those nuts with the silicone **** in them to stop them from coming off? Loctite? weld the ****ers on?
    WTF?
  2. curly2k3
    odd, normally if they're on there nice and snug they stay in place. you could always retighten them after a drive/afternoon too and while its still rather warm in there, it'd let you get more torque on them and a bit more grab probably. otherwise you COULD use loctite.
  3. derp
    i'm currently missing 3 of the 5. >.<
    looks like I get to hope that the sears auto center will let me use a jack. I'm not paying them to install the 1 ****ing nut I can't get to, and that's the only place within walking distance from where I work.
    edit. They don't even open till 9, and I only work till 8... I want to go to bed :(
  4. idget
    So only the top 2 are on?
    I've seen the stud start to back out causing the nut to also back out.
    It's ok to drive with a leak there so no huge rush to get it fixed. Other than it being really annoying. If you have time this afternoon/evening swing by and we can get it sorted out.
  5. derp
    i'm going to run to o'reilly after work and get some of those lock nuts with the silicone
  6. J.Rex
    J.Rex Well-Known Member
    those are supposed to be ceramic nuts and bolts to be able to hold up to the heat
  7. Nuke
    use oem nuts and bolts
  8. Medic_538
    Medic_538 Well-Known Member
    Those will probably not work either. The heat will burn up that silicone in a heart beat. Tried that on my old car, melted it and it STANK!!
  9. AWDimprezaL
    Try using lock washers? I've never had this issue, so as usual, I'm not much help.
  10. xluben
    I agree. Use OEM bolts. They should have a knurled mating surface to prevent them from backing out. The heat produced is going to make silicone/loctite/etc ineffective. I would double check for loose studs, because that could also cause them to back out.
    On my car I've found that I can use a standard length socket and 3/4" drive ratchet, and reach 4 of the DP bolts from the engine bay. I have enough room to put a breaker bar onto the ratchet, so I have no trouble at all tightening them to stud-snapping torque (if I so desired).
    The bottom/middle bolt is tougher to reach (especially with my EWG installed), but I can also reach this one from the top. I just reach my hands around the turbo and use a closed end wrench. No breaker bar, but I can get it plenty tight.
    Just a thought. I'm sure there are other very good methods for tightening these bolts down. I previously had done some of the bolts from the bottom, but I find that working from the top allows more room, and I can get them very tight.
    Another couple notes:
    As already mentioned, a post turbo exhaust leak isn't going to hurt anything. It's just annoying.
    Also already mentioned, retorquing after a few heat cycles, and while the car is still warm (but not burning hot), will often allow you to snug them up a little more.
  11. tangledupinblu
    So, i'm on the phone with him and he's heading to Morries to grab some OEM's.
  12. 2barsti
    2barsti Well-Known Member
    Try looking into self locking copper nuts.
  13. idget
    Try deez nuts
  14. tangledupinblu
    Oooo...can haz!? I've heard that deeez nuttz are tha best nuttz!
  15. derp
    Got oem stuff. And a side of deez nuts just in case. I'll chuck them on in a few minutes, then warm the car up and retorque. We shall see how that goes. Hope no more issues. Wish it was vband instead lol
  16. xluben
    I was thinking the exact same thing last night when I was removing/reinstalling my exhaust manifold/uppipe/EWG/downpipe.
  17. project/driven
    Brett, this has happened to me as well. I haven't lost 4 of the 5, but the last 2 time that I've had to remove the down pipe there has been 1 missing. I've probably removed and reinstalled too many times.
  18. derp
    Well, oem replacements are on. Tightened as much as I physically can. Hopefully that solves it. If not, time for locking hardware.
  19. Starkall
    Starkall Active Member
    Put some high temp rtv silicone on the threads when you crank it down.
