having problems with my car
Discussion in 'Modifications And Maintenance' started by slowrs13, Aug 27, 2008.
  1. slowrs13
    slowrs13 Well-Known Member
    Heres the problem when I do a 4th or 5th gear pull the car starts to bog and spudder at about 4500 rpms.
    I just got the car back from being tuned two weeks ago. Some of the mods include. EJ22T block, wrx heads, vishnu fuel rails, 805cc injectors, 255 walbro fuel pump, Link EMS.
    What i have done so far... new spark plugs, checked for boost leak, put iso heat in the tank and ran two tanks of fuel through the car. I will be getting a new fuel filter and testing that out Friday. Thanks in advance for the advice.
  2. Nuke
    clean your maf sensor first, and see how that goes
  3. slowrs13
    with the link ems you don't need the maf sensor
  4. AWDimprezaL
    gas??
  5. slowrs13
    there could be some bad gas in the tank but i did run fill it twice now so you would think if there was bad gas it would be gone by now.
  6. WRXEcho
    WRXEcho Well-Known Member
    Check the cylinder compression...seriously. My car did the EXACT same damn thing, found out Cyl #3 was down 50 psi. :(
    http://mnsubaru.com/forums/showthread.php?t=26928&highlight=bogging+issues
    It's worth it to check. And if it's bogging, it's probably pulling a LOT of timing. So, my advice is to stop hitting that high of RPM until you check the compression. You could make it a lot worse by pushing it. I don't mean to scare ya', but this is just my experience, unfortunately.
    Not that I want you to go try this, but at WOT, will the car get past 4500? Or does it just hit a brick wall? You could also be over-boosting and hitting fuel cut...but I would check the compression. If you can change the plugs, you can check compression. :) Good Luck!
  7. wrexinator03
    wrexinator03 Banana Cream
    that'd be what i was gonna say was compression... :( i'd also maybe check injectors...one might not be up to par
  8. slowrs13
    I am going to check the compression tomo. And yes the car will go past 4500 sometimes. I am just hoping that i just had some bad fuel...
  9. Rexwagon
    Rexwagon Well-Known Member
    Is it still holding boost or not? is the boost dropping hard? How new is your turbo? if your boost is dropping it could be some shaft play as well
  10. slowrs13
    yes it is holding boost and the turbo is brand new
  11. WRXEcho
    At WOT it goes past 4.5K?
    Cause with mine, if I creeped it up there, it would go past it, but on WOT runs, it would not.
  12. slowrs13
    i can't even slowly get on the throttle with out it cutting out, but sometimes if i get off the gas then get back on it will go past 4500rpm and that is just in 4th and 5th gear.
    1st 2nd and 3rd no problem. could it be the throttle postion sensor? or maybe the tune?
  13. slowrs13
    I did a compression tast today Cylinder#1 140, #2 145, #3 140, #4 145
