headlight bake
Discussion in 'Mini Meets' started by thunderdan1313, May 25, 2010.
time of day
  1. june 20 afternoon
    37.5%
  2. june 20 evening
    56.3%
  3. either
    6.3%
  1. thunderdan1313
    thunderdan1313 New Member
    people keep on talking about baking headlight to black them out
    so i was think june 20 i could host a head light baking/blacking out mini meet at my house. i got room for 20cars+ in the drive way.
    got 2 ovens to bake head lights in.
    people can bring heat guns to part the head lights to.
    i have a 2 stall garage that we could used to paint in
    i will have hookah rolling.
    come out if u have bake head lights before and help out or to come and hang out and smoke some hookah
    DATE JUNE 20
    TIME ??????
  2. Shibbs
    This is a great idea.
  3. JasonoJordan
    agreed if i didnt have mine done already would be there.
  4. blackozone
    This is a great idea. Hookah+paint fumes=win.
  5. idget
    If it's early enough in the day can we call it a headlight wake and bake :biggrin:
    I could probably bring a set of 07 taillights and demonstrate how to cut open and paint those too.
  6. ofspunk7
    MINT APPOVED.
    don't think i will bake my headlights, but i might come for the fun... I will see what time i get out of work. DAMN YOU THURSDAYS!
  7. thunderdan1313
    or we can do it on sunday
  8. RexNEffect
    I'd bring mine as well and get them done. But I can't make a Thursday evening. Sundays work well!
  9. thunderdan1313
    can a mod switch the poll to sundays june 13, jun20 please??
    also what time on sunday?
  10. unhguy78
    unhguy78 Well-Known Member
    i'm for sure down, count me in
  11. Straitup D
    Straitup D Well-Known Member
    Watermelon mint, I am down!!!!
  12. Shibbs
    Mo, paint watermelons INSIDE your headlights. Then chicken out your grille.
  13. ofspunk7
    fixed
  14. Shibbs
    Yes.
    Also, I'd go to either of them, methinks. Not sure what would prevent me from attending.
  15. thunderdan1313
    well i guess can we add one that says both dates or let people vote for both
  16. MMC_555
    MMC_555 Well-Known Member
    Great idea! Will check call schedule and vote/get back...
  17. MMC_555
    Ok, 13th would work best for me...
  18. TheSnowman
    TheSnowman Well-Known Member
    how does the paint you use hold up to the temperatures of HID's?
  19. idget
    I used krylon fusion paint for plastic (flat black) on my STI and they held up just fine. Just needed a little fine grit sand paper and adhesion promoter. If anything, I would worry about the seal. Warming them back up usually takes care of it, but having some extra rtv around would be a good idea.
  20. Shibbs
    HIDs are considerably cooler than halogen bulbs.
  21. TheSnowman
    ^^ huh, did not know that
  22. MMC_555
    Kinda dumb question, but here it goes...
    Does anyone have a ton of paint others can use? or can someone tell me what stuff I should buy/bring (paint, brushes?, sandpaper?) to do this..?
  23. ofspunk7
    That is a great question! People who are doing this should GB the products, because otherwise there will be a lot of waste. I would offer to do it, but I am just coming to hang out... so I don't need any product.
  24. thunderdan1313
    if people want to i can buy some stuff if people want to chip in when they get here. also my yard is not fenced in but i do have a ton of rope that i tie to a tree for the dog. so if u want to bring u dog feel free. also we could do soem bbq if people want to bring stuff
  25. RexNEffect
    I voted for the 13th, but can make the 20th if it's later in the day. NT2 is on the 19th.
    What grit sandpaper and what adhesion promoter did you use Sheen?
  26. MMC_555
    I'm in for a GB of supplies...
  27. jonny8852
    jonny8852 Well-Known Member
    i would be down for this. I've been wanting to do this for awhile now. I picked the 13th, but i believe either date would be good for me
  28. idget
    I don't think you'll need to do a GB. I did 3-4 sets of lights with 1 can of kylon fusion flat black and 1 can of duplicolor adhesion promoter. Rubbing alcohol and dish soap if you don't have any prep solvent. Tack cloths are like $1 each too.
    Just use a scotch bright pad or fine grit (wet sandable) sand paper. I suppose you could go from medium to fine to superfine if you have 07 chromed out headlights and want to go all the way down to the plastic... just use your head when sanding. I prefer not to dig into the plastic, just scuff up the finish.
    list of supplies:
    something to clean the surface (prop solvent, prep wipes, dish soap and alcohol, etc...)
    something to scuff the surface (scotch bright pad, sand paper, etc...)
    something to clean dust off the surface (optional - tack clothe)
    adhesion promoter
    base coat
    clear coat (optional)
    rtv or something to reseal older headlights (optional)
  29. LEGGY_WARRIOR13
    LEGGY_WARRIOR13 New Member
    I'm down, more to probably watch and just hang out, cuuuuuzzz I'm newby like that haha.
  30. StanmoXT
    StanmoXT Well-Known Member
    I need to get my headlights cleared so Im down for this meet up
  31. MMC_555
    I'm thinking this'd be a good chance to change the bulbs to some brighter ones, any suggestions? ('04 WRX)
  32. unhguy78
    i'll chip in for supplies
  33. Rusty
    Rusty Member
    i'll come hang out, either day works for me
  34. MMC_555
    I'll chip in for supplies too...
  35. RexNEffect
    I'll actually be attempting to cut-open my tail lights and painting them, since the headlights are already painted. I'll bring my Dremel and some RTV.
  36. ofspunk7
    Sorry I don't remember off hand. do you have reflector or projector bulbs in the 04? I think you have reflector right?
  37. MMC_555
    Uhhh good question not sure.... I'll have to check.
    A quick google search shows this as the bulbs for an '04 WRX, not sure how accurate this is though:
    Low Beam Headlight Bulb Size: H1-55W
    High Beam Headlamp Light Bulb Size: 9005
    Front Turn Signal Light Bulb Size: 7440
    Fog/Driving Light Bulb Size: H3-55W
    :ugh:
  38. ofspunk7
    Well a quick Google search (which I should have done before I asked the question) shows that your headlights are reflectors. The reason I ask, is to answer your question.... i would swap to projectors and put in HIDs. In My Opinion, a swap to HIDs will be the brightest option. I know that I will put them in all future cars that I own. But that is just me, some people might think it isn't worth the money to swap.
    projectors
  39. MMC_555
    Thanks... I'll look into the HID option, not sure I wanna spend too much on this though!
  40. ofspunk7
    Understandable. I wouldn't want to buy new headlights eighter.... better "performance" things to buy. However, if you already have projectors... i would always spend the $60 on the DDM kit.
    FYI. If you are going to the headlight bake sale at Dan's.... maybe look into just a low beam swap out. Might be way cheaper than new headlights.... not sure what all you have to do.... but might be an option since everyone is taking apart headlights anyways.
  41. MMC_555
    Ok, so evidently I'm quite ignorant in the lighting department... would this just mean putting in new low beam bulbs, or something more involved?? :s
  42. ofspunk7
    so we stop thread jacking you have been PM'ed
  43. unhguy78
    there should be a don't care option on the poll ha its split down the middle almost and my vote can go either way
  44. ofspunk7
    i think that is how most of us feel
  45. thunderdan1313
    im back in town so what day/time
