HELP CEL!!!
Discussion in 'Modifications And Maintenance' started by anthony mendenhall, Nov 28, 2011.
  1. anthony mendenhall
    anthony mendenhall Member
    car: 2004 sti
    OBD2 code is P0103 mass or volume air flow circuit high imput. Any answers??
  2. ShortytheFirefighter
    You haven't been through a carwash recently have you?
    Any other signs of problems other than the CEL? Are you running the stock intake or some sort of short ram/CAI?
  3. anthony mendenhall
    Yea I was through one at about 4pm today. And I have a ram intake, godspeed fmic 20g turbo 1100cc injectors and just got an e85 tune like a month ago
  4. Nuke
    Youve maxed out your intake.
    On cold days, with that turbo, youll be maxing it out.
    You can either reset your ecu or upgrade to a bigger intake
  5. anthony mendenhall
    What intake do you suggest and do you guys have one up there??
    Also if I reset my ecu will my tune be erased??
  6. ShortytheFirefighter
    It's also possible that you managed to get some water into the intake and onto the MAF. I had it happen a couple of times with an SPT intake until I started putting a shield over the filter when I'd go into certain washes. I'd leave the wash and it'd feel like the engine would almost kill and the light would come on.
  7. anthony mendenhall
    Sounds about right too. I was testing some data logging thing on my iphone when it happened. So I was all the way on it!!
  8. anthony mendenhall
    That could be too. I don't have a shield over my filter
