Help identifying issue
Discussion in 'Modifications And Maintenance' started by TheHoboMan, Jul 25, 2011.
  1. TheHoboMan
    2003 Subaru WRX, has a gutted downpipe, gutted up pipe, SPT intake, GMBCS and stock CBE.
    Was tuned a few summers ago by Nuke.
    No CELs, replaced spark plugs and did an oil change about a month ago.
    The sound started a week or so after replacing spark plugs. While in neutral the sound is audible from 1k - 2k, while in gear it's just barely audible while on throttle.
    Should I be preparing for a rebuild?
    Any help is appreciated.
  2. Nuke
    are the spark plugs fully tighten? j/w
  3. kongzilla
    kongzilla Well-Known Member
    Sounds like a loose header with air escaping through it.
  4. FinnNiks
    FinnNiks New Member
    Doesn't sound life threatening, just make sure it has fresh oil, something good like Rotella T6 10W-40 or so. Just stay away from Mobile 1... Stay away...
    I agree though, sounds like an exhaust leak.
  5. kickin_81
    kickin_81 Well-Known Member
    Can't be an exhaust leak. I've had leaks before and they sounded much more tinny/metallic.
    Double check for any missing screws and ensure all engine compartment pieces are secured. Maybe a screw popped off and fell into a crevice above the engine or maybe a portion of the engine is vibrating against something. Not likely the culprit but worth a check.
  6. bikerboy
    bikerboy Subie GOD
    Rod knock, sorry time for a rebuild. Drain your oil and inspect it for bearing material.
  7. TheHoboMan
    Thanks for the input guys/gals(?).
    I always run Rotella 5w40 in my wrx. I haven't had a chance to check the spark plugs but when I installed them I checked, double checked, and triple checked to make sure that everything was tight. After reading a bit more it's probably safe to assume rod knock...and it literally sounds like a knock...lol
    NF Performance you may be getting some business soon for a rebuild..
    Any other advice/opinions are welcome.
  8. TheHoboMan
    Spot on.
    Car is running 100% now, no rod knock, it was just a loose spark plug ><
    Mods feel free to close the thread.
  9. 4drcivicmaster
    Nuke troubleshooting again! ;)
  10. TheHoboMan
    Yeah Nuke is the man.
  11. Nuke
    Indeed he is...
  12. 4drcivicmaster
  13. Nuke
    I'm offended
    Fishsticks
