Help/input please. Noise from engine bay
Discussion in 'Modifications And Maintenance' started by Mr.Tran, Dec 10, 2011.
  1. Mr.Tran
    Mr.Tran Well-Known Member
    2004 Impreza WRX
    It's on it's 2nd ej20
    Mods include:
    Turbo back exhaust
    Grimmspeed Phenolic spacers
    Grimmspeed hybrid boost controllers
    565cc modded injectors
    Turbo inlet
    Silicone Y pipe, throttle and bpv return
    One step colder NGK plugs
    Nuke tune
    255 walboro
    Uncle Scotty's Cocktail mix
    Oil changed a few weeks ago
    Amsoil is the only oil i've ever used in the car.
    I think that's about it.
    Car has 112k miles.
    The motor should be around 30-40k
    New clutch was installed by Turbo_Turtle a few months ago
    Problem:
    I walked out to my car while it was running.(I have a remote start)
    And noticed some noise coming from the engine bay. The noise seems to be coming from the front of the motor but I may be mistaken. Its almost like a metal rubbing against metal sound. Power has not been effected and the car seems to drive fine. I have some video that I will upload and post a link to. Otherwise if any one is available ASAP to check it out I would greatly appreciate it. I'm located in Richfield near the Mall of America. Text/call Anthony at six one two 810 eight nine seven three.
    Thanks in advance.
    Edit: Here is the link to the video I took. Not the best shooting, but it's more for the sound than anything.
  2. idget
    Its really really hard to tell from the vid lol. Are you talking about the constant "scraping" noise? If so, probably a failing belt tensioner or pulley.
    were new pulleys and tensioners (and i suppose belt too) used when the motor was replaced?
  3. Mr.Tran
    Sorry it was windy out. I'll try to make another vid. The previous owner had the motor replaced so I'm not certain. Yes that's the noise I'm speaking of. (Assuming it is a pulley or tensioner) Is the car safe to drive in this condition? I'm assuming not.
  4. JasonoJordan
    Well to narrow it down i would start by removing the ac belt/tensioner if the noise goes away u have found ur issue. If noise persists i would pull the timing covers and do a visual inspection of the pullys and tensioners of the tbelt unless you know for a fact its a new tbelt and tensioners.
  5. Medic_538
    Medic_538 Well-Known Member
    It doesnt even look like the small pulley is spinning. It may be the video? Check on that, if it isn't spinning.... Winner, winner chicken dinner...
  6. Mr.Tran
    It's just the video, it's definitely spinning. I'm gonna try and check the A/C pulley today. Could still use a hand if any one is available.
  7. JasonoJordan
    if you wanna swing down to burnsville i can help you out. Parking stall isnt heated though.
  8. Mr.Tran
    Thanks everyone for the input. Sheen was able to help me out. It was the AC compressor or pulley. Gonna try replacing the pulley first.
  9. JasonoJordan
    Dealer sells the pullys new as does alot of the local parts stores.
    If you want to make sure its the pulley and would like to take one off and put it back on i would let you borrow mine as my ac system has a leak somewhere and its not really doing anything having it hooked up.
  10. FuJi K
    I hate the new plastic ac pulley. The older metal pulleys where better.
