Help me break the bank and get in debt
Discussion in 'Modifications And Maintenance' started by ofspunk7, Jun 9, 2009.
  1. ShortytheFirefighter
    Just don't use Mobil 1, use a decent synthetic and you should be fine.
    A number of us on here run Shell Rotella 5W-40, and there are also people on here who swear by Amsoil.
    Leaving the oil that's in there for break-in won't hurt anything. The important part is staying below 4k rpms and not running at any one engine speed for an extended amount of time (according to the Subaru manual).
  2. Bullwinkle
    Yes, as I mentioned, openecu has definitions to support the canbus ECU cars, so the 09 (and '10, after it comes out) will be supported for openecu tuning.
    Yes really. Doing custom tuning is very hard on your car. The tuner will basically be doing many full wide open throttle runs from 2k to redline. Modern cars are a little better regarding break-in, but you for sure are going to want a number of miles on the car before tuning.
    Regardless of what you do on day 1 of ownership, I'd recommend changing the oil at 500-800 miles.
  3. ofspunk7
    ok that really threw me for a loop. isn't mobile 1, one of the few true synthetics? i know that the oil companies sued so that they could make semi-(fake)-synthetics (super reprocessed non-synthetic oil) and call it a synthetic because of how many times they refine the oil.
    so why is mobile 1 bad?
  4. ShortytheFirefighter
    It's contributed to the killing of a number of motors in the past. It tends to shear down pretty quickly, leading to spun bearings. Searching around on Nasioc will get you a number of threads about it.
  5. AWDimprezaL
    Mobile one is the synthetic version of water.
  6. Ryan
    Ryan Sled drifting master
  7. ofspunk7
    NICE
    ** also thanks for the threads. I did a search and have been reading since the last post. good thing work is slow today. i will check out those other threads. glad i said something about the M1. thanks again for the save on that one.
  8. ofspunk7
    ok here is some outside feedback i got today
    "Did a quick look
    Shell Rotella 5W40 is primarily designed for truck and diesel applications, however, they do approve it for gasoline
    engines.
    Secondly, it is one of those "synthetics" that is not a true synthetics.
    Its base is a XHVI group III, which means it is a highly refined petroleum product.
    Mobil 1 is a PAO base group IV, which is a true synthetic product."
    also what about the oil information on - www.motoroilbible.com
  9. carl
    i personally run oil in my race car.
  10. ShortytheFirefighter
    Do you mind if I ask why you're fixated on synthetics? Not meant to be a dig at all, just curious.
    Trust me when I tell you that the Rotella will be much, much better for your car than anything marked Mobil 1.
  11. ofspunk7
    I have a close family member that is pretty insane about oil. he has been doing research for the past 7 years. looking at the break down periods. the reason i brought this up was i know that the beter the liquid the better and longer my engine will run.
    i like the info on rotella - but it is one of the oils that sued for the right to be called synthetic even though it isn't.
  12. zyklon
    zyklon Well-Known Member
    Run whatever oil you like. Just check your level often.
    Don't try to reinvent the wheel with oil change intervals, even if some eBook told you to. Change at manufacturer's specs, especially during the warranty period (especially if 09's are still blowing, ringlands, was it?)
    If you really want to know what's up with your oil, every couple changes send a sample off to Blackstone. They will tell you what's going on with it, and whether or not you can extend your change intervals.
  13. ofspunk7
    i have no problem changing at the correct times, just want to do what is best for my car. I don't plan on runing 5k to 10k on the oil.
  14. Bullwinkle
    Rods and rod bearing issues on the 09 WRX's. ;)
    But yes, nothing incredibly special about oil. Use a decent oil and change it often, and your engine will be fine.
  15. ofspunk7
    i think i'll pick the happy medium. my source says AMSoil or M1, because they are both true synthetics. every thread i have read today says AMSoil or Rotella. sounds like AMSoil is the way to go.
  16. wrxin
    wrxin Well-Known Member
    +1 for rotella. i switched over to it recently from m1. my car feels a lot better with rotella in it.
  17. Shibbs
    For a true synthetic, Amsoil or Royal Purple. I've used both with very good results on both. The car really seems to love the Rotella tho. Comes out alot cleaner than the Amsoil did.
  18. Bullwinkle
    Where are you guys buying the Rotella-T locally?
  19. wall of tvs
    wally world
  20. readymix
    I buy all my Rotella T at Wally World. Rotella T 5w-40 was recommended to me by a guy that builds Subaru motors in Las Vegas. He did oil analysis on it vs. Mobil 1 and a couple other oils. It had the best properties with regards to wear and tear, and breakdown. Mobil one turns to watered down crap very quickly. If you run it in your WRX, you'll notice that around 2000 miles your car doesn't feel the same as it did at the time of your oil change, and at 3k when you do your oil change, it'll feel like a whole new car again...till 2000 miles. And repeat. With my built motor and setup, the engine feels consistant the entire 3000 miles between changes. And everyone that I've recommended it to has fallen in love with it (ask Musashi). Also, Rotella-T 5w40 HD is a true synthetic, not that it matters, what you need to care about is the wear properties and the lifespan of the oil. You could put pure synthetic oil in your car all day long, but if you are getting excessive wear on the pistons/cylinder walls and the oil is turning to piss quickly, then the whole synthetic thing becomes moot.
    I will never switch back to Mobil1 as long as I drive cars. Any sports oriented vehicle I own that recommends 5w-30 will get RotellaT 5w40 until they stop stocking it on the shelves.
  21. ofspunk7
    this is not true. it is a refined oil where they try and refine it enough to take the larger molecules out of the oil. these are the ones that break down quickly in regular oil. They only try to leave the shorter molecules. they actually took this to court saying that because they change the molecular structure of the oil it can be classified as a full synthetic when it really isn't. amsoil is a full synthetic.
  22. piddster
    Rotella was made for diesel engines which see a much much much harsher environment than our gas engines. 16:1 or higher compression and over 30psi, not including the soot. I will from now on run Rotella in my aggressive engine.
    Just take your time on your mods. I understand that you want some rubles off the bat. $800 is a bit steep for a catback imho. If you can wait a month or two, you can get something nice for waaaay less money. Patience is a virtue in this world. I've been modding my car for almost nine years now.
    Sounds like DarkDan is your family member. We had a little snit and I will never post on fivezeroseven again. That is all.
  23. ofspunk7
    yeah I am not saying it is bad. I don't have anything to go on because i have never used it. i was just saying that it is labeled a synthetic because of some fancy lawyers won a case so they could market the label that way.
    don't know who this person is. no my family member is like 50 and doesn't really do the forum thing.
  24. subarusnowman
    subarusnowman New Member
    I am not speaking with knowledge or opinion but when I purchased my 09 3 weeks ago...Subaru Dealer said Subaru DOES NOT recommend using a synthetic oil....just an
    FYI..they also told me use BP or Shell gas only....just passing this along if someone wants to agree or not....
  25. ofspunk7
    yeah i am sold. check the link a few pages back. there was a few pages about gas. it is weird because when it used to be Amoco i dated a girl in high school (like 12 years ago) and her dad would freak if she didn't take her mustang 5.0 to Amoco to get gas.
  26. readymix
    And Group III base stocks are still consider full synthetic. Again, it doesn't matter about whether it is "full" synthetic or not in this regard. Also, just because an oil uses Group IV base stock doesn't mean it is comprised entirely of Group IV base stocks. It is still blended oil.
    And if you want to split hairs, here's a fun tidbit for you about Amsoil...
    read this first: http://en.wikipedia.org/wiki/Total_Base_Number
    specificly this part:
    Amsoil Premium 5w-40 TBN = 8.0
    Rotella-T 5w-40 TBN = 10.6
    So for half the cost, Rotella is going to have a better ability to suspend crap in your oil. Also, Rotella-T 5w-40 is made with the same base oil that Helix Ultra is made with. They use that in Ferrari Formula 1 cars. Stop worrying about the base stocks of oil, as not all base stocks are created equal, and base stock isn't what the entire quart of oil consists of.
    Just because they say the juice uses pure florida orange juice concentrate, doesn't mean the entire jug is filled with 100% Florida Orange Juice concentrate. They could have topped off that orange juice concentrate with raw sewage. I'd much rather drink 10% juice concentrate with 90% clean water.
  27. Ninjaplease!
    The early build 09s had issues with rods and rod bearings. Mine was a build date 08/08 and it went. The later build cars arent having the issue. Either way, its not a reason to not buy the car. If it happens, Subaru is very good at taking care of the issue, as well as the customer. If I could rewind and do it all over again, I would still sign the papers and take er home.
  28. ofspunk7
    damn... see that i what i love about forums. you think you have a well rounded answer and someone goes and drops some knowledge on you turning your whole world upside down.
    and I think i am going to just drink the sewage water and skip the OJ.
