"help Me" Fuel Cut When Wrx Turbo Spools
Discussion in 'Modifications And Maintenance' started by demong, Sep 21, 2007.
  1. FuJi K
    MODS on the car are:
    headerback exhaust no cats; 3"TBE. Everything before the turbo is stock.
  2. AWDimprezaL
    front 02?
  3. FuJi K
    W/ the gas more than 50%, the engine like CUTS OFF and no exhaust pulses. W/ my AP connected and on LIVE DATA, AFR shows 16, which is LEAN. There are no pulses at all until the RPMs drop to 600-700 and the car chokes and tries to stay on and you can hear burbles. Idles just fine at 14AFR avg.
  4. AWDimprezaL
    fuel pressure?
  5. demong
    demong Well-Known Member
    Fuel pressure,
    might be involved with the fuel delivery system, hmm,
    will update thread with a link to a youtube video of the issue,
    I really think my car is dead this time.
    ouch
    started it up 5 minutes ago,
    makes a loud whining noise in the rear.
    then RPM guage drops,
    THEN CAR DIES,
    nooooooooooooooooooooooooooooooooooo
  6. Substeroo
    Substeroo Well-Known Member
    den it must be fuel pump.
  7. Substeroo
    new walbro stat!
  8. demong
    uploading video now,
    message me if you guys want to see more videos so you guys can build up a diagnostic conclusion.
    thanks everyone.
  9. demong
    At startup neutral
    wow,
    i thought my car was really done for.
    it just happened a few minutes ago at neutral start up.
    dang it,
    no more highway driving.
  10. demong
    While watching the video, listen real carefully when I start the car.
    notice that loud whining noise.
    well, it's above average.
  11. demong
    heres the uploaded video
  12. Substeroo
    well, the video is only somewhat useful. There's a lot of clicking from you handling the camera. Can you get closer to the whining noise? Video tape that with out moving all around (put the camera down on a stable surface). Then we could get a better idea I think.
  13. demong
    New update,
    seems like I can't Rev Pass 2000 RPM.
    Fuel cut is now at 2000 rpm.
    oh oh,
    its getting more worst.
  14. WRX1
    Did you log it yet?? You have spent too much time making a video that doesn't show anything, log it.
  15. Nuke
    demong, we'll log it later and see how it goes.
  16. demong
    i have to see if i can actually make it to firestone today. car is acting like its gonna break down at any minute.
  17. demong
    Maintenance update
    Yesterday night,
    the spark plugs were replaced and problem wasn't solved.
    Check up and did a swap with the IMF sensor. That didn't work.
    Nuke came by and did a computer diagnostics check on the vehicle.
    Max fuel load was only at 33 percent compared to another test vehicle at 100 percent fuel load.
    Next maintenance would be on replacing the fuel pump.
  18. Nuke
    Aye, check your PM
  19. WRX1
    What does that mean?? Your IDC's are at 33%??? Fuel load???
  20. demong
    Does anybody know anything about the maintenance schedule or actual life of fuel injectors and fuel rails.
    Could there be a possibility that there are mineral deposits causing a restriction of fuel to the engine?
  21. wall of tvs
    I think he meant fuel pump duty cycle.
    It's probably not the pump itself but rather the fuel pump controller.
  22. demong
    hey,
    can I get more information on that fuel pump controller?
    What happens if the fuel pump controller malfunctions?
    Has it happened to anyone you know before?
    What's the maintenace life of a fuel pump controller?
    where it's located, where I can access it and does it make any sound?
    oh yeah,
    and the price for the unit and how easy or hard can it be replaced?
    thanks
  23. wagonL
    wagonL Well-Known Member
    okk.....so far....me, demong, and silver sti pheng...swapped out his fuel pump...and its still the same results....the thing i notice is taht when i start it..it'll jump up to 2k rpm and drop back down... if you try to give a little throttle it wont even go anywhere..it'll die instantly....so...im thinking that it has to do with a sensor...but not sure where...and also...there's no check engine light....so ya..
  24. kvang
    kvang Well-Known Member
    charging system???
  25. wagonL
    well..i was thinking that it could be his coil on plugs...but not too sure yet...dont wont to do anymore damage to it...
  26. Nuke
    try the fuel pump controller
  27. AWDimprezaL
    try commas
  28. wall of tvs
    Eh, I've gotten used to his banter over the years (ie, I just ignore it now).
  29. demong
    Last resort is the dealership. thats going to cost me big bucks.
    I'm planning to do a full newbie technical strip down and refurbishment.
    It's always good to have spare parts for my wrx so i'm going to go ahead and order a bunch of stuff so I can do a full diagnostics and figure out the problem.
    I sure hope I don't cause any more harm to my car.
    "there has to be a solution to every problem"
    "i want to fix the problem as soon as possible"
  30. WRX1
    So how is that free log coming along......
    $5 says the solutuion to the problems has already been posted.
  31. Sogonerg
    Sogonerg Anteater
    take internet checks?
  32. k_thaosta
    k_thaosta Well-Known Member
    Does it choke when you rev to your limit?
    If so, it could be the turbo "locking" or "seizing" (don't know if this makes any sense) as I have had this problem before and the tech guy at White Bear told me that... I don't believe in what everyone tells me, but at the time I didn't know much about the car, this was years ago. Didn't pay a dime, covered by warranty at the time and got a new shortblock too...
    You could be doing more damage to your engine than you already know it by now by testing out all sorts of things... Just log it like what Russ says...
  33. TSTRBOY2004
    as opposed to throwing a fuel pump in it after people said it wasnt the issue?? should have chucked a walbro in or better...
  34. AWDimprezaL
    this has to be by far one of the most retarded things you could possibly do, throw parts at it.
  35. demong
    Hey guys,
    seems like if there is a fuel limit then the rpm won't be able to reach turbo spool.
    fuel limit caused by the fuel filter
    fuel pump acted out loudly because it was having trouble with pumping fuel through the fuel filter,
    replaced the fuel filter and everything should work out just fine.
    I guess it's part of a normal maintenance for a vehicle
    so the problem was basically the fuel filter.
    thanks to all forum members that gave feed back on the site
    thanks to t-rex5000 for giving me some understanding that there is a clog on the fuel delivery system.
    Special thanks to my subaru buddies that helped me figure out the problem and helped me swap out my fuel pump,
    Dao,
    Pheng,
    Fong,
    Xai,
    Fuji,
    Lue,
    Mike
    You guys rock and thanks for helping me get my car back into running condition.
  36. Nuke
    foo, u forgot me punk
    anyways
    quit pumping that 87 crap man, I told you saving 2 bucks isn't getting you any chicks
  37. demong
    oh yeah,
    i also forgot you Nuke,
    thanks for analyzing the problem.
    Super america gas is just pathetic, octane set at 92. My car had problems after I pumped there.
    I'll probaly go down to M&H for 93 octane this time
  38. Cubby
    Cubby New Member
    M&H 93 is iffy. Sometimes its good, sometimes its REALLY BAD, enough to make my car choke. That was when I was still NA too.
    Shell V-Power 92+ ftw.
  39. FuJi K
    So you've been putting 87??? or is Nuke just BSing??
  40. Nuke
    I'm messing with him about the 87, it was a joke I made when I was trying to help him figure out the problem
    but it's probably some shtty gas
  41. RallyImp05
    RallyImp05 Well-Known Member
    you are running 87 in a boosted engine?!?!? why? just piss into the gas tank why dont you?!?
    ahh nvm just read on... have you been pumping a holiday? they have some ****ty gas..
  42. retreif
    Most of the gas for all the stations in this area come from the two refineries on Hwy 52 in Rosemount. The tankers get each brand's additives splashed in them and then dump the fuel in the station's tanks. So the only difference between gas at one station and the next is the additives and the physical tank at the station. Besides the different octanes of course...
    Edit
    one is in Rosemount, the other off 62 in St. Paul Park.
    /edit
  43. retreif
    I'm sure this topic has been visited (and revisted) but I think when people point out 87 octane is bad here is something to back it up:
    http://vettenet.org/octane.html
