HELP PLEASE
Discussion in 'Modifications And Maintenance' started by quizno73, Nov 14, 2011.
  1. quizno73
    quizno73 Well-Known Member
    this past friday i was driving my 02 wrx wagon and all of sudden my car started to make horrible metal on metal noise and had a rough idle. i pull over fast and shut off the car and got it towed to my work. i then tore it apart and found the idler bearing blew up and there were no ball bearings in it so i had no tension on my timing belt BLAHHHHHH FML i then look at my timing marks and it jumped :( any advice or does anybody know where i can get cheap heads or manufactured heads ? or can help me fix them ?
    pleasse help
  2. Mr.Tran
    Mr.Tran Well-Known Member
    Did it do any damage to the pistons? It might be a good time for a rebuild.
  3. quizno73
    haven't tore it apart yet i gotta buy new timing belt kit and retime it and then do a compression test to see if i ****ed up the valves :( and to see if i need to take it apart.......
    SS1 block here i come lol
