Anybody want to do some routine maintenance stuff for me. If you know your stuff….give me a holla. Between work, grad school, and my son ….I’ve basically been neglecting my ride in the maintenance dept. I will purchase the necessary parts / fluids and pay you for your time and a case of beer. Here is what I need done: 1. Replace driver side front wheel bearing assembly, AND perform front/rear wheel bearing lubricant. The wheels are making a sqeaking noise when moving. 2. Replace Brake pads, linings, front/rear axle boots, CV joints, axle half shaft, parking brake. 3. Brake fluid 4. Replace engine coolant 5. Drive Belts (also making a sqeaking noise)
Just a suggestion... Make sure they drink after the perform the work... Not during... I just had bad experience when i drink and work on cars... Let's just say it takes over 2 hours to do a oil change...
