Help with noise
Discussion in 'Modifications And Maintenance' started by Will Thammavongsa, Feb 15, 2012.
  1. Will Thammavongsa
    Will Thammavongsa New Member
    So this noise just popped up a couple of days ago. Please tell me its not one of the timing belt tensioner pulleys. I have plans on doing the timing belt this summer since my car only has 92k on it. And I believe the mileage interval is 105k for the timing belt. Any who heres the noise help me diagnose it.
  2. Ronnie@RSmotors
    Only way to know is to diagnose further. Remove the drive belts one by one and see if the noise stops. If it doesn't then it's in the timing components.
  3. Will Thammavongsa
    Thats the plan tomorrow morning.
  4. Will Thammavongsa
    okay its confirmed that its the ac tensioner
  5. tangledupinblu
    Glad to hear that it wasn't something worse/moar expensive!!:)
  6. Will Thammavongsa
    yeah same here. I was ready to do the overhaul i planned for the summer next weekend lol!! Put stock exhaust manifolds back on new gaskets, timing belt, valve cover gaskets, fix oil drain leak from vf39. Phew!! relieved, now I can have time to port the stock manifolds.
  7. issues
    issues Well-Known Member
    it was 44.34 at subaru the other day for me dont get the napa one its a pile my last one failed in 6 months. you dont need the bolt kit unless you loose it or screw up the threads.
  8. Will Thammavongsa
    I was wondering how much the ac tensioner pulleys were. Looks like I'll have to hustle the subie dealer again. How do u remove the threaded part? I just removed the whole tensions assembly since its winter. Didn't take the time to look at the pulley.
  9. issues
    remove the nut in the middle of the pulley, when you put it back in leave the nut loose.
