Hey So I just finished modifications on a 2002 subaru wrx and I am at the point where I need some help with tuning. I have a cobb accessport and possibly looking for someone to help with pro tuning if possible. I have installed: hks ssqv bov with recirc fitting walbro 255 fuel pump spt intake turbo xs FMIC vf-39 turbo sti pinks wideband sensor any help would be much appreciated thank you much
Are you running an OTS VF39 map from Cobb? Sounds like they're "designed" to handle the parts you list, other than your FMIC. I'd think it would be safe to run your setup with the Cobb OTS map, maybe don't beat on it until you get ProTuned by someone like @NF Performance, @Ronnie@RSmotors or @Jason@DB - any of them could probably tune your setup in their sleep and/or hung over edit - added DB, forgot their username : )
I am currently running the vf-39 map and was hoping that would solve my problems. I am at the stage where i am trying to find out if i can just get it tuned or if i made a mistake on installing a part or two. I have the problem of misfiring on all 4 cylinders currently so i am not even trying to drive till i can find someone to help with a baseline or help run over some ideas quick. I know reading on some other forums that people were able to just get tuned and the problems was fixed. haha lets just say im a little stuck
Post more details about the symptoms, sounds like you may have basic issues that will need to be resolved before the tuning process can be performed - although it's not uncommon for some tuner to be willing to help you resolve non-tuning related car issues as well, for an hourly shop rate. But maybe posts symptoms/info here first and see if anyone has ideas...
