HID Kits on the cheap
Discussion in 'For Sale : Car Parts' started by techy101, Sep 29, 2008.
  1. techy101
    techy101 Well-Known Member
    35w is OEM on HID's. you can't compare output by wattage between lamp types. IMO 35w are plenty bright
  2. Vector
    Vector Rally Organizer
    35w unless you really just want to piss people off.
  3. 02blubru
    even with her having projector headlights???
  4. Vector
    Yes. 35w will be really bright. 55w will be blinding.
  5. subytek
    subytek Well-Known Member
    Don't go any more than 35w. PLEASE!!!
  6. StatGSR
    StatGSR Well-Known Member
    hmm iv been thinking about getting a set of hids for the teg, i just might have to do that at this price.
  7. 02blubru
    I will be ordering hers when we get the cash. I just got mine in today and installed them. very easy install. I got the 4500k 35w low beam only.
    <---thinking he should of waited a week and saved some extra $$$$ for the high/low combo.
    oh well they are still brighter then my stock high beams, well what ever bulbs I bought from vector. They actually do not look to bad for being in a bugeye, was just out driving around and did not get flashed at all. I like them better then my old set I used to have. they do not seem as obnoxious.
  8. Vector
    IIRC the ones I sold you had stock wattage low beans, and 100W high beams, so they were only brighter than stock when the high beams were on, otherwise they were normal.
    Actually, I should have at least one set of those (used) if not two sets (1 used 1 new) in the garage somewhere from my old bugeye.
  9. 02blubru
    Yep thats what they were. these HID's are brighter then them even the high beam.
  10. Vector
    No doubt. A 35w HID will put out more lumens than a 130W halogen. So there's going to be more light than a 100W, for sure.
  11. 02blubru
    lol. I did like, them. I kept them so if I ever go back from the HID's I can.
  12. AspitFire
    i ordered up the 5k kit last week hopefully i have it next week
  13. pksublime
    pksublime Well-Known Member
    mine are coming today
  14. TSTRBOY2004
    we were discussing this last night... what would work in the 04 Foresteer?? Driftin.. refresh my mammaries
  15. 02blubru
    I think he said our bulbs are 9003 which are equal to an H3. I am not a 100% sure on that. but I did see a high/low beam kit for either of the above numbers.
  16. Vector
    The 04 Forester indeed uses a 9003. But that's not equivalent to an H3 in any way shape or form.
    H3:
    The H4 is very similar to the 9003, and a lot of places sell bulbs that are labeled as both, but some 9003s are a bit longer, and have the filament in a slightly different place. But they are essentially interchangeable.
  17. 02blubru
    so since they do not list and option for 9003 should we go with the H4 option??
  18. Vector
    From what I know, yes. But I can't be 100% certain, because I don't have the bulbs here to verify (though I think my Sentra runs 9003, but it's out on the trailer and I'm not climbing out there to look at the bulbs right now, you'll have to excuse me).
  19. techy101
    I have always seen the Forester labeled as an H4, not a 9003.
  20. Vector
    Sylvania lists it as a 9003. I think it might be a European vs. Asian standard difference. Same bulb, but two different standards organizations.
  21. 02blubru
    what did you order for your forester??? I just picked one up and need to start doing things to it.
  22. subytek
    He got them for the SVX, not the forester.
    Bill, if your going to get them, get the high/low kit.
  23. 02blubru
    thats the plan, just making sure I was ordering the right number.
  24. Vector
    Finally installed the set I got for my wife's car. It was an H1 set for an Altima, and the install took a little effort, mostly because you have to take out the coolant reservoir, the windshield washer tank neck, and the airbox just to get to the damn bulbs on the car. then the weatherproof covers for the back of the light housings had to be drilled out to fit the larger grommets. The lights themselves were simple to wire in (plug and play), and work great. Very nice cutoff, no hotspots or scatter. Helps that the H1 bulb happens to line up pretty much perfectly with the HID capsules and the Nissan housings are designed for a HID retrofit (OEM part) also.
    We'll see how they hold up, but so far, they look good.
  25. Gridlocked
    Alright, I've read through this twice and I'm fairly confused.
    Mark, you seem to be the lighting guru around here. If I go this route, will I get more of a standard light pattern out of the Morette lens? The eruo light pattern is driving me crazy - granted I know I need to adjust them, but I already get flashed and they seem extremely low to me. With the standard (non HID) Morette lens the blind spot on the drivers side is awful. I'm picking up a set of bugeye OEM lights and am going to run those until I can figure out weather or not I can swap the lens on the Morettes. I have E-mailed probably 10 vendors, including Morette to find out if the low beam lenses can be swapped out with the same size lens that throws a us pattern, but no one knows.
    I've got that set of Denali HID lenses, bulbs and ballasts that I want to try to butcher, but not if they won't fit.
  26. techy101
    changing lamps will have no bearing on your light pattern. If you have the euro style designed for LHD then this will just make things worse. You'll still blind oncoming traffic, just in a much worse way.
  27. Vector
    What techy101 said above. are you saying that your Morettes are RHD pattern (Japan & England) or "Euro" most of which is LHD like the US?
    If you're getting flashed, putting in HID bulbs really, really won't help.
    Measure the lens of the low beam. If it's around 3-1/2", it should be possible to swap in the Hella 90mm modules.
  28. Gridlocked
    Yeah, they are a RHD light pattern:
    ................................___
    ...........dark............../
    ...........area.........../ light area
    ______________/
    light area
    Honestly I don't know why I am getting flashed. If I'm behind a car 40 yards, my headlights don't even light up their drivers side tail light. It's friggin annoying.
    I measured the diameter of the low beam glass completely- not just the spherical lens inside of the light itself. I have not had time to take off the cover to have a look at what mounts where. But are you saying that the whole low beam assembly can likely be swapped out? Also, how is this light pattern caused?
  29. techy101
    Regardless of why you are getting flashed, HID's will just make it worse. If you are looking to do a real true retro THESE guys sell some very high quality OEM projector assemblies. Also the forum on that site has more information than you could ever, ever want to know about doing retro's.
  30. Dream
    Im interested in HID's for the wagon, wasnt there a group buy that happened? How are those kits holding up?
  31. techy101
    This wasn't a group buy, just their new pricing. So far mine have been just great. I've had two times where for some reason one lamp didn't strike properly, but a quick turn off and back on of the headlights fixed that right up.
  32. Shibbs
    They're on sale right now - an extra 5 bucks off!!
  33. Dream
    I just ordered a set of 4500k's, cant wait!
  34. subytek
    You will love them dream, I just installed the same thing on Thursday.
  35. AspitFire
    yea mine are wonderfull
  36. Bullwinkle
    I've got a similar set from CNLight. Install was cake on the '06 WRX, and the light pattern with the stock projectors is awesome.
    I also bought some plug'n'play LED's for the city lights, as I didn't like the look the bulb had with the HID. The cool-white LED's look perfect with the 4500's I got.
  37. bobafett04wrx
    bobafett04wrx New Member
    I want to get a set for my 04, I need H1s correct?
  38. bobafett04wrx
    I just ordered a set of 5000k.
    Anybody want to help me install these? I know its probably not that hard but I don't know much about electrical. And help from someone that has used this set would be nice.
    I can pay by a case of beer!?
  39. Dream
    How long did it take for you guys to get your kits?
  40. Vector
    A week, week and a half? But I ordered just when their huge shipment came in, and so i was like the 1,000th+ order queued up.
  41. 02blubru
    1-2 weeks for me 2 weeks for the bugeye ones and 1 week for the foresters
  42. pksublime
    few days
  43. stick
    stick New Member
    They show two kits.
    DDMs at $55 and Apexcones at $40
    Seems that the only difference is the ballast size.
    So, does the lifetime warranty cover the bulbs? If not, how long should they last?
    I have silverstar bulbs in mine now and they seem to last less than a year and they are $25
  44. Shibbs
    Bulbs are warranted for life, I have asked. Its a pretty sweet deal.
  45. TSTRBOY2004
    can you pm me the part number for yours.... I may have to put this on my wish list from the mother in-law for christmas
