horn not working, think its the relay.
Discussion in 'Modifications And Maintenance' started by mrantegra, Mar 31, 2010.
  1. mrantegra
    mrantegra Well-Known Member
    minneapolis
    almost got hit today, try to honk but didn't work. fuse is good. I think its the relay went to pep boy they didn't have it but it was open. part # is 82501FC000. how much are these at the dealer? Might stop by the dealership in tonka.
  2. pattertj
    pattertj Member
    Savage
    I'd post in the Morries Parts thread or give them a call for an official quote, but a quick google shows them around $35-40 online.
  3. mrantegra
    minneapolis
    thanks, might stop by napa to see if they have it. that's pricey.
  4. John16V
    John16V Well-Known Member
    Are you sure is not the clock spring at fault? One time my RS horn didn't work and it turn out to be the clock spring. Anyway GL with the repair.
  5. thunderdan1313
    thunderdan1313 New Member
    minnetonka
    take out another relay like on for the wipers and place that in the horn relay spot to make sure is the relay
  6. mrantegra
    minneapolis
    when I honk it just make a click sound. most of the people say it's the relay but i'll try that tomorrow.
  7. mrantegra
    minneapolis
    it has those hella tone or whatever it is call.
  8. Dynapar
    Orono, MN
    ^ I have the same issue with my supertones. I dont even get a click when I push the horn button. Please post up if replacing the relay fixes the issue for you.
  9. prezawagon
    prezawagon Well-Known Member
    Redmond
    I would use a multimeter and try to debug the problem before buying a relay, it could be a bad ground, etc. Especially since the supertones would require some custom wiring that could easily get corroded. Also, if there is a second relay (common for supertone installs), check that as well.
  10. TheSnowman
    TheSnowman Well-Known Member
    Twin Cities MN
    my fuse went out on my hella horns to. my stock fuse was fine just needed to replace the fuse that came with the horns and then they worked great.
  11. mrantegra
    minneapolis
    not the relay. I didn't even know there was a fuse for the supertone. i dont see it but havent look at it yet. thanks guy.
  12. idget
    falcon heights
    They don't come with one, but a proper install will include a fuse between the battery and the relay for the supertones.
  13. mrantegra
    minneapolis
    found that fuse, its actually the horn, just connect back to the stock. :( I need new tires for my bike so probably won't buy new supertone.
  14. pksublime
    pksublime Well-Known Member
    i was going to say that you can find the replacement relays on sites like digikey for WAY cheaper
