how to remove rear bumper?
Discussion in 'Modifications And Maintenance' started by Taras, Mar 7, 2008.
  1. Taras
    Taras BANNED
    Planning on doing a little project but need to remove the rear bumper. Does any one know how do to that? Maybe some has a picture with the location of all the bolts?
  2. KSAL
    KSAL Well-Known Member
    I don't know if its just like the STi but there are clips right behind the trunk that are a HUGE!!! BI*** to get in and out! Sorry no pics
  3. Taras
    Taras BANNED
    i think i found the directions on nasioc, but they are for a wagon.
  4. Colin
    Colin Well-Known Member
    To take a bumper off:
    Remove the clips that connect from bumper to wheel well.
    Open trunk.
    Crawl under car and remove the 4-6 bolts (17mm i believe) that hold the bumper beam to the car. You may need to move your muffler and the gas fume box thingy.
    Remove the entire bumper and beam from the car.
    Easily remove all the bothersome clips that hold the cover to the beam.
    Note: When reconnecting the beam to the car, be very careful to not strip the bolts/holes. I have heard many people do this. Also, make sure everything is aligned otherwise you bumper will look like it has many ass cracks.
  5. Taras
    Taras BANNED
    Thanks. It would be really nice if someone who has access to repair manual could post up a pic with the location of all the clips and bolts.
  6. Colin
    Honestly if you need a picture for this, you should have someone help you do it. It took me 30 minutes to switch over to a lightweight bumper beam without any previous knowledge.
  7. driftin240
    driftin240 Well-Known Member
    No bolts, just push clips. IMHO, if you don't have the faith in yourself to just start taking it apart, you shouldn't be touching it in the first place.
  8. Colin
    ^you can get to the top clips. they're under the unibody.
  9. Nuke
    Ok Taras...what are you doing now?
  10. Taras
    Taras BANNED
    I am sure its easier than putting in the inlet pipe.
