how to remove the transmission
Discussion in 'Modifications And Maintenance' started by that-dude, Jun 7, 2009.
  1. that-dude
    that-dude Well-Known Member
    where can i find a "how to" to remove/replace the tranny? like a step by step or what bolts/screws i need to take off? im planning on taking out my auto tranny from a 96 impreza coupe w/2.2L. any info will help, thanks
  2. prezawagon
    prezawagon Well-Known Member
  3. ej20
    ej20 Well-Known Member
    Also try omods.com
  4. KSAL
    KSAL Well-Known Member
  5. qstarin
    qstarin Well-Known Member
    Something those guides for clutch changes won't mention is your torque converter bolts.
    There should be a little rubber cover in an access hole on the top of the bellhousing on the engine (mine was sort of under & behind the intake manifold on the passenger side). You'll want to take those out (6 bolts iirc) so that the torque converter comes off with the tranny.
    Also, I had issues clearing the front axles from the tranny. What I did was take the castle nut off the bottom of the balljoint and pound off the a arms. That allowed me to pull on the hub assembly and pull the axle (still attached at the hub) right out of the tranny with plenty of room for it to clear the tranny.
    Some people will say this is unnecessary and as you lower the tranny the axles will have enough room to be pulled out, but that wasn't true in my case.
