Hybrid Build Q's...
Discussion in 'Modifications And Maintenance' started by Kevin, Jul 28, 2008.
  1. Nuke
    If you don't mind short gears, the MFactory is another option.
  2. Kevin
    Kevin Well-Known Member
    of course i want the six speed! i just dont have the money for that right now, it was good meeting you the other night!
    More info on this please!
  3. Kevin
    Update:
    Picked up the new shortblock today! its so fresh and clean
    also got some preasents in the mail:
    ARP head studs
    Cometic head gaskets
    ACT clutch
    Picked up my new cam gears from subaru yesterday
    the 2.0 is stripped, just need to get some plugs and small stuff transfered over
    all i am waiting on to start putting it back together is the gasket kit and a torque wrench lol
    i am very excited to get this thing done!
  4. Nuke
    The MFactory gears are about $2300 for all 5 gears I believe.
    Go on nasioc, transmission area, and you'll find more info on it.
  5. Kevin
    yeah i did that, not sure on that though... only 350 ft/lbs capable? if im going to fork out the money for my transmission i would likt it to be able to hold more than that.
    i just wish i could find a 6 speed swap local....
  6. curly2k3
    Fobia?
  7. Scuba Steve
    OMG congrats on the short block!!!!!!!!!!!!!!!!!!!!!!!
    another nexb question here. compression ratio- how did you figure this out?
  8. RexXNXmotion
    Online
    RexXNXmotion Guest
    Enjoy the block:)
  9. Kevin
    i didn't, MAP did lol, i bought it from RexXNXmotion, who bought it from MAP, they built it specifically to accomidate the wrx heads. not sure what the ratio is, i still need to figure that out.
  10. Kevin
    Got my turbo today! Woot! just waiting on my gasket kit and **** can start to go back together! I am going to delete my tgv's once i find my dremil... its somewher in the garage... i think lol.
  11. w_o_t_boy
    w_o_t_boy Well-Known Member
    http://www.csgnetwork.com/compcalc.html
  12. readymix
    Probably 8.75:1 on the CR, or close to it. What Cometic headgasket are you running?
  13. Kevin
    its a 3 layer, dont remember the thickness...
    got a good amount done today...
    heads bolted on the block
    oil pickup and pan on
    header
    UP pipe
    turbo
    bunch of cooling lines
    water pump
    picking up my 08 oil pump, cam seals, and valve cover gaskets tomorrow
    should have it almost all back together tomorrow! i hope! lol
    then i hope to have it back in the car on friday!
    wish me luck lol
  14. Kevin
    so i have everything bolted on the motor!!!! its almost ready to go in... tomorrow i will pull it off the ngine stand with the hoist, bolt on the flywheel, clutch and presure plate then put the tranny on and it should be in the car tomorrow!!!
  15. curly2k3
    congrats, let us know how tuning goes and what you put down
  16. Kevin
    ITS IN!!!! still in the process of hooking everything up but the motor and tranny are bolted on there mounts!
  17. vanddelor
    vanddelor Well-Known Member
    congrats dude...
  18. Bullwinkle
    In the interest of people looking, I found some interesting info in this thread on NASIOC. Posts #40 and #42 are very interesting, and seem to indicate that most people doing a hybrid build would benefit more from building off of a 06-08 EJ255 WRX motor vs. a EJ257.
    I know it's a little late for Flatline and some of the other local guys doing hybrid builds, but some food for thought...
  19. Jackstand
    Jackstand Well-Known Member
    That is interesting nate thanks for the good info
