I/C spray
Discussion in 'Modifications And Maintenance' started by 08summit, Sep 21, 2009.
  1. 08summit
    08summit Member
    Does anybody know where the I/C sprayer resivoir is located on an 06 STI?
    My light came on today and it wont come off when I push the sprayer button. So im assuming im out?
    Please help, I am a noob :(
  2. predavore
    predavore Well-Known Member
    Trunk, right side?
  3. 08summit
    08summit Member
    Thank you predavore.
    Also what is best to fill it with, just regulator water or something special?
  4. predavore
    Probably something that won't freeze. Clear windshield washer fluid?
  5. subytek
    subytek Well-Known Member
    We have a winner.
    On a side note, does anyone ever read their owners manual? It says this kind of thing in there.
  6. 08summit
    08summit Member
    Honestly never came to mind.
    But thanks to both of you.
  7. Snowbum
    Snowbum Well-Known Member
    I think your suppose to put vodka in there....That should be in the manual too
  8. olegrad
    olegrad Well-Known Member
    iirc, it says on the cap water only. just don't use it in the winter.
  9. turbo_turtle
    I've been used distilled water (to keep the system clean) and I try to get it near empty before winter time. I'm not entirely sure of how the plumbing goes with all the fittings and valves and such, but the lines haven't burst yet from freezing. There's probably some relief valve somewhere which lets expanding water backfill the reservoir. Just make sure your tank isn't near full come freezing time.
    ~Dan
  10. blackozone
    Use distilled water, don't use anything that has alcohol in it. If your I/C has anything painted on it, you'll end up slowly stripping the paint off if you use alcohol.
  11. cwin
    cwin New Member
    I second this.
    Also, like everyone else says. Make sure you only have the tank 1/2 full before the temp drops.
  12. 08summit
    08summit Member
    Thanks for all the input guys. Much appreciated.
  13. piddster
    OMG! You'll loose the paint off your intercooler if you use alcohol. Yet, alcohol is more effective.
    I'd use acetone since it is the most volatile solvent legally available, but you might not like the smells.
    The smells!!!!.
  14. 08summit
    08summit Member
    Oddly enough i enjoy the smell of acetone...
  15. piddster
    Acetone is great for lots of stuff, but it might be nasty to the pump and lines. Smartass I am...
  16. blackozone
    Yeah, by all means, load your plastic tank, lines, and nozzle up with acetone. You have fun with that one.
  17. AWDimprezaL
    throw in some clear washer fluid, baam, not that big of a deal.
  18. piddster
    Maybe liquid nitrogen? Actually, Diethyl ether has the lowest boiling point. hmmmmm :p
  19. webcrawlr
    webcrawlr Well-Known Member
    I don't think I'd be spraying anything combustible under the hood of my car... that's just me. Like most others, I use distilled water.
  20. putz
    putz Well-Known Member
    gasoline is combustible, and you spray that anytime it is running, right?
  21. webcrawlr
    Are you fer serious? Lets see.. gas is being sprayed inside my engine in an controlled environment... alcohol is being sprayed directly on your intercooler were the evaporation can certainly flash with the turbo being just under it. Yeah, I see the comparison.
  22. blackozone
    You should use liquid nitrogen.
