i fix 1 problem...only to get another one!!!
Discussion in 'Modifications And Maintenance' started by mkhang, Jul 15, 2009.
  1. mkhang
    mkhang Member
    Ok..so I fixed my wheel bearings and axles just a few weeks ago. I'm driving home from the cities and there's a loud grinding noise coming from underneath my car and I don't know what it is. The noise is loud, super loud. It sounds like something is grinding and/or rubbing. It gets louder and louder but I have no time to take a peak or have it looked at. THEN tonight as I'm driving home, whenever I put it into 1st gear and drive, it jumps a little and sounds like something is really loose and grinds. I don't know what it is, but I'll try to get a video of it up tomorrow. The noise is really terrible and I'm afraid it might be my transmission
    , but I'm really hoping that we just did a bad job on our axles/wheel bearings lol. I don't know if anyone has had this problem before, or would know some sort of solution? And if it is my Tranny/Transfer case, anyone selling one? lol
  2. Musashi
    Female
    Clouds
    Here is are some questions: does the noise increase with speed? Does it get worse as you go faster? Does the this happen with other gears?
  3. TheHoboMan
    St. Paul
    I don't get why it's so hard for people to post details of the car they are driving...
  4. ShortytheFirefighter
    This times eleventy.
    This is a forum, it's not a guessing game. If you want help, you better be able to put together a post that contains all the information we're going to need to help you. If you're not able to do that, then we're not going to be able to help you.
  5. PhilSine
    PhilSine Well-Known Member
    MNBugeye Mafia 007 (Superior)
    I had that problem once when I did a rear wheel bearing. I thought it was in square enough but discovered on its removal that it was slightly askew. I re-did the bearing using a bit of grease while sliding in the new bearing (old one was toast) and made sure it was properly seated. That solved my problem.
  6. mkhang
    mkhang Member
    ok sorry that i forgot to post my car haha. it's just a stock 2003 WRX Impreza. No mods what so ever. but the noise just gets to a higher pitch as you go higher in speed. and the jerk only happens in 1st gear, and sometimes in 2nd. I'm gonna try to get a video of all the different things happening later today.
  7. mkhang
    mkhang Member
    Alright...so we looked at the car today. We have a good idea that's its somewhere along the lines of my tranny/differential/driveshaft. we're not really 100% sure yet...so i think it's time we open up my tranny :( anyone have a spare tranny for me? haha. it makes a loud grind and a big jerk when i release the clutch out of 1st gear, and there's a ton of noise everywhere after the car is in motion. so we figure its my tranny or somewhere around that. hopefully the fix won't be expensive..i'll post a video up as well. does someone know how expensive it will be to fix this problem?
  8. Nuke
    Saint Paul
    center differential?
