I need a tune ASAP!!
Discussion in 'Modifications And Maintenance' started by Kevin, Mar 26, 2008.
  1. Kevin
    Kevin Well-Known Member
    I currently have 750cc injectors with a wolboro 255 and am looking to get tunued on e85 now! lol
    i also have an intake and exhaust.
    just wondering if anyone who is familiar with open ecu tuning would be willing to do it for me either tonight or some time soon.
    please let me know.
    Kevin
  2. tux121
    tux121 Well-Known Member
    do you have a wideband?
  3. Kevin
    yes i do
  4. wrexinator03
    wrexinator03 Banana Cream
    noob question but do you lose anypower running e85?
  5. Kevin
    no... totally opposite.
    it is ecentially 105 octane
    plus it burns a lot cooler so you can bring down intake temps
    and it changes your powerband and makes good amounts of tourqe!!!
    very nice!
    so who wants to tune it?
  6. wrexinator03
    so what your saying is since im pickin up a walbro255 and bigger injectors anyways i should just get my tune for e85???
  7. Kevin
    what size injectors are you getting?
  8. SubeN'Siren
    SubeN'Siren Well-Known Member
    You can gain power.
    E-85 is high octane, for cheap, though you have to run almost 30% more fuel by volume, so dollars per mile is close to premium pump gas.
    High octane, and higher heat of vaporization (means the fuel cools the cylinder better than gasoline), lets you run more timing, and perhaps a little leaner.
    Ethanol also produces higher volumes of exhaust gasses, being that it has oxygen built into it (the reason you need to inject more), so even though you're exhaust gas temps might be cooler, turbo spool is equal to, or even better than gasoline.
    For more info:
    http://forums.nasioc.com/forums/showthread.php?t=803341&pp=25
  9. Shibbs
    It can start to push the limits of the stock clutch tho. Especially on a 2.5 I've heard.
    That's all in how you clutch tho.
    Also more stress on the transmission.
    Torque kills bugeyes. :p
  10. tux121
    I'm not sure but you will have to interest someone into the tune if you want a free tune. You did want a free tune am I correct?
  11. Kevin
    so any tuneres on here
  12. fobiawrx
    fobiawrx Fabiola
    go to rs motors and talk to ron if you want it fast. thats if they have time with the whole remodel going on
  13. Dream
    Agree'd, Ron has been putting out some nice numbers on E85.
  14. Kevin
    just looking for somthing for now. rs is busy till sat
  15. techy101
    techy101 Well-Known Member
    Why can't it wait until Saturday?
  16. Kevin
    it can... just trying to get my car back on the road.
  17. hella_sti
    hella_sti Well-Known Member
  18. AWDimprezaL
    too bad tom is dead
  19. subytek
    subytek Well-Known Member
    Maybe he will grace us with his wisdom about running it, pros and cons. I believe he said that he had to retune for every tank of it, because the blend is always changing. But I don't know for sure, I've never run it.
  20. Kevin
    you dont have to completly re-tune it... you might have to adjust the fuel scaling a bit to compensate for a little different blend.
    i am very excited to run it, and i wish tom would chime in cuz i wouldnt mind one bit if he was willing to tune it for me, i saw the numbers he made on his car!!! very nice!
  21. wall of tvs
    Yeah, you don't necessarily have to "re-tune" the car every tank -- you just need to run a perm. mount wideband in the car to keep an eye on your WOT (ie, open loop) AFRs since they will tend to skew away from target after around two tanks.
    By skewing, I mean you might be off by ~0.2 AFR points. Yes, I'm a bit anal, hahaha.
    And just as Flatline said, it's just a quick change of the overall injector scalar to bring things back into alignment. To figure out the correct change takes a few simple calculations (break out your maths toolkit).
    On my car it went something like this -- run a ****load of timing, lean the crap out of it (~12.7:1 gasoline-equivalent afrs), run as much boost as the turbo would allow, and screw around with AVCS. I bet I spent 2 or 3 entire days just working on AVCS alone......if only my car had it on the exhaust cams, I would've probably made an extra 20hp up top.
    I actually kind of want to switch back to e85 pretty soon since that tune I had was so much better than my regular gas tune I'm running now (ie, I'm too lazy to fix the few things I don't like about my gasoline tune, lolz).
  22. Kevin
    so with that said tom... would you be willing to give me a decent street tune?(i am not looking for a handout, there would be payment involved)
    i just want a good drivability for now until the summer blend comes out.
    W_O_T_boy gave me a base map just want to get it cleaned up and drivable for now.
  23. Kevin
    is there anyone that would be willing to do this for me this weekend?
    turns out rs cant get me in sat, so i dont know when i will be able to....
  24. Nuke
    C'mon Tom, just one more...
  25. wall of tvs
    sorry, no time thanks to 70hr work weeks
  26. B-REX
    B-REX Well-Known Member
    PPG Transmission: Check!!
    I think that should be the first mod for any bugeye. :laugh:
  27. Nuke
    You sir, need a vacation.
