I think I just might start hunting deer, especially in Bloomington..
Discussion in 'Modifications And Maintenance' started by RexNEffect, Sep 23, 2009.
  1. RexNEffect
    So, in case you didn't read about it yet, I avoided a deer on East Bush Lake Rd this past weekend, except my passenger front rim did a face-plant into a curb doing about 40 mph.
    Confirmed damage so far is the control arm, sway bar, fender, sway-bar, both front and rear rims, side-view mirror, and other cosmetic damage. Basically, the wheel is 5-6 inches moved to the rear from where it should be. The insurance adjuster is coming out tomorrow to check out the damage and give a base estimate. But, I'd like to get someone else's expertise on it.
    If anybody that has alot of experience with this kinda thing (hint hint Scuba Steve, Idget hint hint) and has tomorrow off, I will make it worth your time. I work from 4:00pm to 8:00pm, and the car is located in Bloomington (near Normandale and 494). Please PM me. Sonja is hurting, and it's making me hurt (yeah, I'm an emotional bastard when it comes to cars).
  2. TheSnowman
    TheSnowman Well-Known Member
    that sucks man. i hope everything goes good with the insurance comany
  3. cwin
    cwin New Member
    It's good to hear you are not hurt. The damage sounds extensive, it will be interesting to see what the adjuster says. Good luck!
  4. Kevin
    Kevin Well-Known Member
    that sucks... shoulda just taken the deer....
    you are looking for someone with expertise on what?
  5. putz
    putz Well-Known Member
    sorry to hear this.
    It's just better to hit the bastards. They just stand there and stare and wait and then jump in your way again when you change course. They derserve death, alone, on the side of the road, hell... I'd get out of the car and urinate on their dirty deer carcus.
  6. AWDimprezaL
    Things that could also be damaged, inner tie rod, engine crossmember, and C channel.
  7. piddster
    I don't know if they still do it, but for several years the City of Bloomington would have sharp shooters take deer along Nine Mile Creek.
    Always take the deer.
  8. cwin
    cwin New Member
    I've splatter-gutted one deer in my life, the damn thing came out of nowhere. (well, the ditch) I was also always taught to aim toward the deer, let off the gas and hope for the best.
  9. Scuba Steve
    :eek:sounds like Ojibwe rally! We did the same thing, except it was a rock.
    Control arm, tie-rods, ball joint, fender....all damaged. All easy stuff to repair, but as 3rik said, the entire front end/corner should be carefully inspected.
  10. Tim the Plumber
    depending on the speed you are going and if your taking a corner... letting off the gas may be a very BAD idea
    Yes Carl it looks exactly like your wheel Caterday night at Ojibwe
  11. fischer881
    fischer881 Well-Known Member
    I grew up in Bloomington and graduated in '06 and my buddies and I had a bike path we road on that had sharp shooter signs up. So I would assume the are still doing that.
  12. Shibbs
    If you're driving that close to the limit on public roads....
    :nono:
    :iconpolice:
  13. scoobypwnz201
    **** id have beatin the bastard with a bat if he did that to my car...
    then id thank him
  14. Tim the Plumber
  15. RexNEffect
    This is kinda what I was looking for. Things that need to be mentioned to the adjuster and taken into consideration.
  16. RexNEffect
    Progressive agent came out and setup the tow and shop (Hamline Auto) to get her repaired. He did notice that the roof had a small indent in it right above the passenger front window that was never there before...
    What kind of summers could I find brand-new from a tire store that would be at least decent for around $500 a set? I'm probably shootin' too low on the price, but what's recommended? That's the amount I'm guessing the insurance company will give me to replace them, and I'm trying to keep my money contribution to a minimum.
  17. Shibbs
    225/45/17 I'd personally recommend the Dunlop Direzza DZ101, or the Goodyear Eagle GT, for tires in stock @ discount.
    Kumho Ecsta ASX is also a good alternative.
    The Star Spec is an excellent tire, and its right in that price range as well, though it would have to be ordered, according to Discount Tire.
    I highly recommend the Star Spec for a summer only tire.
  18. RexNEffect
    Yep, these look like the way to go at $117/ea:
    http://www.tirerack.com/tires/tires...45WR7Z1SS&vehicleSearch=true&fromCompare1=yes
    They won't be on the car long, since I'll switch to my Glacier II's in about a month or so. Hopefully they'll fit whatever new rims I'll get in the spring.
  19. gran0393
    gran0393 Well-Known Member
    yeah they still do the sharpshooter thing...its actually really easy to qualify for, if you are a pretty good shot with your bow at 30 yards
  20. RexNEffect
    Hmm, I think I may just take up bow hunting...
  21. ShortytheFirefighter
    Sorry to hear about your car! :(
    I took one out a number of years ago with a Ram 3500 crew cab. If you have to hit a deer, a big diesel pickup is the way to go. It's counter-intuitive, but always take the deer. It goes under Comprehensive instead of Collision from what I've heard. Either way, glad to hear that you weren't hurt!
  22. Tim the Plumber
    what about me I was in the car... ooohhhh my neck whats the number for you insurance agent again?
  23. Roon
    Roon Well-Known Member
  24. RexNEffect
    Hold on, let me check my accounts... Nope, 2k not in there. :rolleyes:
  25. Roon
    :rolleyes::rolleyes::rolleyes:
    I am open to offers :).
  26. RexNEffect
    $200?? ;)
    And Tim, there's a case of Killians in your fridge to help with that neck. :laugh:
    Got the base estimate from the Hamline Autobody. Just under $6k. Quick list of damage:
    Bumper scratches
    Fender (replacing)
    Control arm
    Lower and upper sub-frame
    Tie-rods
    Sway-bar
    Oil pan dented
    Front and rear wheels (being replaced with remanufactured ones)
    Tires (they were gonna retread the new tire to the same depth as the other three, but convinced them they were craptacular, and they will be throwing in about $500 towards a new set)
    Roughly 2 weeks before I get her back. As for the roof indentation, they didn't think it was caused by the collision, but they will be running a laser-line? along the frame to be sure nothing's out of place. There's no way the dent was there before the accident, so it had to be from the impact.
    To be continued..
  27. Mr. Derek
    Mr. Derek Well-Known Member
    6k and you didnt even take the deer out. I would be dissapointed lolz. So where do you sign up to be a archery sharp shooter haha. I used to be pretty good with my Hoyt but now I switched to BowTech, havent had a chance to even shoot it yet.
  28. Tim the Plumber
    the roof dent could be from my massive dome flying through it brian tell your insurance company they need to send over a hot lil nurse to administer the killians... or im sueing
    HEELLLLOOOOOOO NURSE!
  29. gran0393
    metro bowhunters at http://mbrb.org/mbrb/
    the proficiency test is pretty much put 5 of 6 arrows in a pie plate at 30 yrds
  30. Nitrofish
    Nitrofish New Member
    Hitting curbs is supposed to be reserved for winter time.
    Did the insurance company doubt that you were swerving for a deer or did they take your word for it?
  31. RexNEffect
    Took my word for it, and Tim was obviously a witness.
    Tim, if they get you a nurse, I'm getting a hottie in a swimsuit to wash Sonja. Girl on girl(car) action FTW!
  32. carl
    wow that sucks brian. way more damage than the SlowTI had.
  33. RexNEffect
    Just got to see the progress this morning. They are just waiting for the door, fender, and bumper to get painted, then they'll put the wheel back on and get her aligned and test drive it. Crossing my fingers I'll have her back tomorrow, and that they don't find anything else wrong.
  34. tonyM
    the wheel looks straight! awesome Brian!
