Idle issues after fuel fill-swapped
Discussion in 'Modifications And Maintenance' started by Threshld1, Jul 18, 2011.
  1. Threshld1
    Threshld1 Well-Known Member
    Alright well I have been kinda lurking with this thing but I have a 97 Outback I put an 06 EJ257 into (yeah... I'm still not quite sure why I chose this chassis either haha).
    I swapped the ENTIRE (engine+bulkhead+rear) 06 electrical harness into her and merged it to the doors/lights/HVAC of the outback. It is a pre-emissions rev chassis so the charcoal canister was up front (vs the new canister behind the passenger wheel) and I am using the outback fuel tank w/ 06 fuel pump/controller.
    My problem is almost every time after I fill the tank, within 10 miles of driving, I get a sputter/stall at low revs/idle. Trying to restart requires a bit of cranking as it seems to be a flooded. If it doesn't die I can hold her at 1500 for a little while and it clears up totally. Otherwise once she fires it will rev up and drive fine for the rest of the tank. No CELs are being thrown. Though I have turned off all emission codes related to tank sensor/solenoids as they are not plugged in/do not exist.
    I'm guessing its a fuel tank breather issue since I don't have the charcoal canister and is forcing fuel back through the breather hose.
    Anyone have any ideas how to remedy this?
  2. Threshld1
    Thoughts? Anyone.... Anyone... Bueller?
  3. Nuke
    if the evap hose vented or not?
  4. AWDimprezaL
    Dont fill it up? 3/4 of a tank sonnnnn!
  5. Threshld1
    Haha I knew I should have put "besides not filling it full" in that last post. I will be doing this but would like to come up with a way to keep fuel from getting in the breather line as I'm sure its not great for the manifold vac lines/solenoids. A check valve wouldn't work as it needs to breath both ways correct?
