If its not one thing its another!
Discussion in 'Modifications And Maintenance' started by Paul Revere, Jan 11, 2009.
  1. Soupboy
    Soupboy Well-Known Member
    Time to consider driving it to a 'hood and leaving it running with door open on a poorly lit street corner...
  2. Paul Revere
    I was thinking Fiesta
  3. Bielke55
    Maybe i'll get Ka Ka's moms old car running and drive that lol
  4. Mortasaurus
    Mortasaurus Well-Known Member
    I have a fiesta. That thing WILL NOT DIE!! My sister hit two deer over the course of a week and a half in it and I have ran it up and down old log trails up at my parents lake place for years. The worst that has ever happened is I ran over a tree I knocked down with it and a branch come through the floor and nearly crotched me!!
  5. Paul Revere
    Buyin one!!!!
  6. Mortasaurus
    Haha. Word of advice though..........Don't drive it in reverse as fast as you can and then throw it into drive on asphalt. It sounds like a good idea but I lost first gear last time I did that.
  7. TSTRBOY2004
    yeah butt Chet will still be licking brians butthole (refers to trash talk thread)
  8. Paul Revere
    ^We are bunking together, anything is possible.
  9. TSTRBOY2004
    noice
  10. Paul Revere
    It just continues!!!!!! Tonight the car wouldn't break above 10psi and it felt really funny. Can you have internal wastegates freeze up? I mean it is COLD out there!
  11. idget
    Freeze open bc of the cold? Probably not... especially with the amount of heat that goes through the turbo. Did the actuator arm c-clip pop off? Maybe the hose? What are you running for boost control? Sounds like you're running wastegate pressure.
  12. Paul Revere
    Well I guess should say will not ... it sees peak boost occasionally well take that back last time I saw peak boost was this morning at 9:30. Then went to school at 5 and came home at 9 and well it would act real funny.
  13. Paul Revere
    Well looks like I am not making it to the ice races, priority number one is get a safe tune!
    I can't seem to figure out what is wrong with my car and these freezing cold temps are not helping!!! :(
    My ******* self got a tune on one of Minnesota's best choices for gas ... not thinking about winter and the winter blend. I started getting CEL's from stations that were not giving me CEL's in the fall and early winter about a 3 weeks ago. I started logging and saw nothing out of the ordinary to me. Until yesterday I sent my logs to Nuke and he showed me I was getting knock from 2300-3200 (fine correction was -1.4 to -1.05) under load while doing a 3rd gear pull. Then instructed me to take 1* of timing out of that area and do another pull. Great well today got say 10* colder than yesterday and after the initial pulls the knock went away. Then things got bad ... I think. I started to get a fine correction of +.35 at some points and my AIM was going in between 16 (where it has always been) to 14-15-16-15-16-15 where it stayed at 15.
    Any advise? I would post my logs so that folks could see but I don't know how?
    Thanks
    Chet
  14. Paul Revere
    Anyone with a leak down test I can borrow before the ice races? Or any shop I can go to? Or compression tester?
  15. HoLsTeR
    HoLsTeR Well-Known Member
    thats not what you told me when you came into my work a couple weeks ago...
    you were so surprised that i dont really try to boost my car at all in the cold months.:cool:
    "i drive it like i stole it!"
    thats why your car is making noises. your driving it like a 16yr kid in a civic. its gonna go to hell after too much fun
  16. AWDimprezaL
    Word!!!!
  17. 02blubru
    I got tuned in the warmer months with good gas.. my car is still running just fine!!
  18. Paul Revere
    I don't think are cars are anything alike.
    Mike you said you didn't cause your tires. And just cause I accelerate daily doesn't mean I don't keep up on maintenance. ... Cough coilovers cough cough.
  19. Bullwinkle
    Chet, all of this sounds completely normal. Of course having your IAM at 16 is ideal, but having your IAM bounce between 14-16 is perfectly normal and safe (especially on the 2.0L WRXs). The Subaru ECU is designed to do this as gas changes depending on location within the United States.
    -1.4 feedback correction (knock) and -1.4 fine learning correction (learned knock correction) are also fine. I would say anything more negative then 1.4 is bad, but learned -1.4's are still perfectly safe. -1.4 is the smallest correction the ECU will save, and simply means there was one singular knock event in that RPM/load area and the ECU learned to pull timing.
    Positive fine corrections are good. This means your car is adding timing back in because it is happy.
  20. HoLsTeR
    your not getting my point. you were almost bragging about how much you beat on the car everytime you drive it haha. i said i dont do snow shens because my front camber making it understear... thats not really a maintenance issue thats just suspension settings. and idk what i could have said about tires other than i just got new ones on... where were you during that convervaion?
    my point was that you were telling me that you love to really rip on the car. thats whats gonna rip on your engine lifespan
    i dont accelerate hard on my car in winter to keep it good for the summer
  21. Paul Revere
    I let my engine warm up and I guess I don't consider I "rip" on it. After blowing one motor trust me I'm on top of everything.
    Thanks for the kind word Nate, that reassuring.
  22. readymix
    Cough oil change cough cough.
  23. RichWRX
    RichWRX Well-Known Member
    bah... I change my oil one evey 15k in my work car if I remember
  24. Paul Revere
    And again get your facts straight Jason, I did an oil change 1k previous to the 2.5qts leaking out. I've ALWAYS done my oil changes on time.
  25. AWDimprezaL
    But you didnt check your oil in that 1k miles? Retard.
  26. Paul Revere
    Cough oil change cough cough is insinuating I didn't change my oil. And yeah in my previous car I had no need to check my oil, even with 150k on the 4.6 I put 5qts in and it had 5qts 3k later. Guess this ain't no domestic :dunno:
  27. 02blubru
    other then to make sure you had oil. I am not trying to be an ass or anything but it could work great for 150k but at 151.5k something happens and there goes your oil. It takes 2 seconds to check it.
  28. Paul Revere
    Thats a chance I guess I was willing to take, and more so is my aunt now that she owns it. It went to hell in a hand basket in less than a month.
  29. RichWRX
    So are u coming ip?
  30. AWDimprezaL
    High, *******, turbocharged cars use oil its a ****ing fact.
  31. Paul Revere
    Don't give my spot up if thats what your asking, I got one full day left! :biggrin:
