If timing is off
Discussion in 'Modifications And Maintenance' started by ej20, Jan 6, 2009.
  1. ej20
    ej20 Well-Known Member
    This happen to my neighbors car but I was wondering is it true. We tried to start my neighbors car but all we get was, like a half crank then it stops and everything(interior dash) kinda dims out. Even with a new battery its still the same. If the timing is off a bit, will the engine crank/start?
  2. Ylime
    alternator/thread.
  3. wrexinator03
    wrexinator03 Banana Cream
    ^thats not his question...yes even if timing is off a car should atleast try and turn over
  4. AWDimprezaL
    If its a fresh battery, even if the alt is dead it should start it up. what was done to the car to make the battery die? working on it? been sitting for a while?
  5. WRX1
    Sorry, fail.:biggrin:
    Can you spin the motor over by hand?? Use a big wrench/breaker bar. With a fresh battery it should spin over. I would guess even on a interference motor that a fresh battery would have the power to bend a valve if it had a run at it. Maybe not if the piston was already in contact with the valve. But would you hear some clanking if the piston was hitting the valve.
  6. carl
    what's the history of this car? when was it last running? any engine work between then and now? generally, timing doesn't just get so far off the car doesn't start all by itself
  7. sniper1rfa
    sniper1rfa New Member
    If the timing was off enough to cause that, you'd hear a big CLANG every time it stopped.
    Sounds like a bad starter motor, maybe. Could be a shorted winding or bad commutator, something to cause the motor to stop producing torque (bypassing a winding and shorting the circuit). That would explain the rapid increase in draw (the dimming lights) and the poor output of the starter (the thing stopping once it makes some compression).
  8. ej20
    Neighbor car was a Mits Expo(beater). First problem they got was oil got in the plugs and wouldn't start so they got that fix along with new timing belt. It was doing fine for about a year now until the other day it just happen. Car was park for about 2-3 days before it happens. They bought a new battery and it would do the same as the old battery.
    Engine will spin no more then 3 times(than fewer) and come to a stop. Interior lights still on if you put to the click b4 starting the ignition. When the engine is trying to crank up, the interior dash lights will dim with the rotation of the engine.
  9. carl
    the timing was 180 degrees off in my sr20det when I first started it. all it would do was crank and crank and crank
  10. carl
    one of the grounds could have corroded and is making a poor connection now
  11. blackozone
    I'm suspicious of the starter. You have given no information that would make me believe the timing belt has slipped.
    Does it seem like the starter is struggling to spin the engine at all or is it turning "3 times" like normal?
    Edit: I supposed sitting for 3 days could have caused the belt to sag and gave it enough slack to slip a tooth or two.
  12. Dynapar
    This is what I am thinking. I had a problem similar to this, where I would get 1 crank on the motor and the lights would dim. Cleaned up my battery terminals (didnt even look that corroded) and it fired right up.
    As for the timing that wont affect it turning over. I had the timing off by about 7 teeth on my car once and it started up and ran. It did not run very well (black smoke, loud noises, general choas/death) but it did start up and idle roughly.
  13. Ylime
    booo i thought maybe i was right for once i iz failz.
  14. AWDimprezaL
    You win. :laugh:
  15. WRXEcho
    WRXEcho Well-Known Member
    crank position sensor? :dunno:
  16. WRX1
    Muffler bearings and blinker fluid.
  17. piddster
    ^ Actually, I was thinking kenueter valve. They like to stick in the cold. New ones are made of unobtainium, so the issues are taken care of.
  18. Ej22TIM
    Ej22TIM Well-Known Member
    check the marzel vanes on the lunar wane shaft.....
