Im sorry for posting this.
Discussion in 'Modifications And Maintenance' started by 25iguy, Apr 3, 2008.
  1. 25iguy
    25iguy New Member
    Plymouth,mn
    I'm a noob and i've been having clutch problems ive gone thru 3 clutches in 35,000. I own a 07 25i and ive been putting wrx/sti clutches in and they dpnt seem to sound right I dont know if that sounds funny but when i take my foot off the gas it sounds like the flywheel is rattleing sounds almost like a grinding. So i come to you wondering if i can put a 02 rs clutch in, and or if its ok to put the wrx/sti clutches in. I'm sorry if I upset any one with this I just dont know qhere to look any more. Please help me out.
  2. carl
    we gotta gooooo
    3 clutches in 35K?!?! who's being doing the installs?
  3. 25iguy
    25iguy New Member
    Plymouth,mn
    Modern
  4. John16V
    John16V Well-Known Member
    Before we jump to any conclusion why don't we diagnose the problem first. What is your driving style? Do you rest your foot on the clutch?
    I mean it might not be you because it might be the person who installs the clutch.
    Give us more info?
  5. AWDimprezaL
    Monticello.
    sti clutches wont work in 2.5is so there is your problem, probably along with bad BAD driving
  6. tbone
    tbone Well-Known Member
    MN
    any mods beside 3 clutches?
    i don't see any reason to put sti clutch into the 2.5i.
  7. 25iguy
    25iguy New Member
    Plymouth,mn
    I've got some tunning done along crank pulley, altornator pulley, Spec.flywheel fadanzza friction pad act stage 2 fr wrx headers back air filter for the motor
  8. 25iguy
    25iguy New Member
    Plymouth,mn
    Them i forgot Modern auto installed it. Well they fired that guy who put my last one in cause he was having problems.
  9. AWDimprezaL
    Monticello.
    pretty sure you cant have wrx headers on your car, totally utterly different
  10. 25iguy
    25iguy New Member
    Plymouth,mn
    Sorry stage 2 ACT with fadanzza friction pad, Headers back
  11. tbone
    MN
    so what is the power HP/TQ u put on this car? did u dyno it?
  12. 25iguy
    25iguy New Member
    Plymouth,mn
    120hp at 6100rpms and 119tq at 4800rpm
  13. 25iguy
    25iguy New Member
    Plymouth,mn
    So can i use a 02 2.5 rs cluch
  14. putz
    putz Well-Known Member
    why don't you put a good 2.5i clutch in, it should easily hold 120whp.
  15. AWDimprezaL
    Monticello.
    i dont understand why you arent using a stock replacement 06 2.5I clutch
  16. Nuke
    Saint Paul
    how do you installed a wrx headerback?
    I just can't see how that'll work for the na car
  17. putz
    this too, I don't think modern would make this error.
  18. 25iguy
    25iguy New Member
    Plymouth,mn
    I had planed on buying some heads and a shortblock. When my first clutch burnt out i replaced it thinking it would last.
  19. Nuke
    Saint Paul
    take it to the stealership and pay up to get it done by a subaru tech
  20. ArcticWolf
    ArcticWolf Well-Known Member
    Moorhead, MN
    Correct me if I'm wrong in the divisions of this list, your jumble of text is... a jumble.
    2007 Impreza 2.5i:
    -Tuned
    -Crank pulley
    -Alternator pulley
    -...Flywheel(?)
    -Fidanza friction pad (?)
    -ACT Stage 2 ... ?
    -WRX header back ....?
    -Air filter
    That being said...
    WRX headerback? As in... up pipe, turbo(?), downpipe, cat section / midpipe, axleback? Missing the obvious bit, in bold. Nevermind that it (the exhaust pipe diameter) is too big (flows too much at the expense of velocity) and you lose low end, if you're still NA (and given the 120/119, you are)
    OEM clutches are fine, really. Unless you swap for a turbo motor, or do some insane race gas build, you're not going to be pulling nearly enough torque out of the motor to overwhelm the stock clutch.
    3 in 30k though, sounds like driver error or terrible installs... or both.
  21. AWDimprezaL
    Monticello.
    doesnt meant he isnt turboed, i mean martin made 108 hp TURBOED :laugh: sorry i had to do it :laugh:
  22. SomethingsWrong
    Directing Rochester's Finest Amish Midget Pr0n.
    Is this about right?
  23. ArcticWolf
    Moorhead, MN
    haha zing :laugh:
  24. Ej22TIM
    Ej22TIM Well-Known Member
    MNSubaru B-Series Member #713
    snap!
  25. Taras
    Taras BANNED
    Saint Paul, Minnesota
    Rotfl!
  26. TSTRBOY2004
    cough cough...
