Is this noise familiar with anyone? Update: Short Block being replaced by Subaru
Discussion in 'Modifications And Maintenance' started by Chaotic Yeti, Oct 21, 2013.
  1. Chaotic Yeti
    Chaotic Yeti Well-Known Member
    "And then people wonder why people buy extended warranties! Good thing everything worked out good for you." - 02_Rexxxy ?
    I think he was just commenting on how some people scoff at paying for warranties.
  2. Chaotic Yeti
    Mike is a straight up guy. My wife and I have another kid on the way, and she has been eyeballing the 7 passenger Tribeca for years. The FXT is looking a little small when factoring in another carseat. At this point Minnetonka may have won us over with a sale. We'll see. Other Subaru dealers may have honored the warranty just as well, but everyone at Minnetonka has been good people so far. I like dealing with good people.
  3. ShortytheFirefighter
    See Scott Putnam in Sales, he'll take care of you.
  4. Chaotic Yeti
    Probably won't be till after spring, but thanks for the go to.
  5. Chaotic Yeti
    Stopped in to the shop to drop off the Killer B oil pickup. Talked a bit with Mike about timing. Sounds like I may get my car back next Wednesday or Thursday.
    Schikane likes this.
  6. Chaotic Yeti
    Just talked to Mike at Minnetonka Subaru. Sounds like it could be up and running in an hour or two. He said they may keep it over night for a cold start in the morning, but everything has been going smooth so far. I'll update again when I have it at home.
  7. DIRTY D
    DIRTY D Well-Known Member
    brake in mode time, watch the RPM's for for at least 1,000 miles. Enjoy :cool:
  8. Chaotic Yeti
    Yep. And a new clutch. Should be fun.
  9. Chaotic Yeti
    Well, hopefully this ordeal is over. Car is back home in my garage. Everything went great. Mike is a champ.
    spudd, Nhibbs and Medic_538 like this.
  10. TMF
    good deal, glad to hear that it all worked out!
  11. spudd
    spudd Well-Known Member
    You're lucky they got it covered having a tune done. Any time we have a turbo motor have a failure under warranty, the first thing subaru wants is for us to check the CID (computer id number) which will change from the predetermined number if flashed
  12. Medic_538
    Medic_538 Well-Known Member
    We should be lucky Subaru's start with such a ****ty tune!
  13. Chaotic Yeti
    No luck involved. They knew it was tuned from the get go.
  14. spudd
    That's why Im shocked they covered it!
  15. Chaotic Yeti
    They could of turned it down, and I suppose somewhere else may have if I would have gone to a different dealer. Mike said when they took the block apart there were no signs of abuse. The bearings most likely failed at some point. I stopped driving it when I started to hear the noise. Than, I babied it to a couple places before leaving it at the Minnetonka Subaru.
    Subaru knows there is a hobbiest community around their cars. I am a happy customer knowing they could have turned me away due to modifications, but instead ponied up.
    spudd likes this.
  16. idget
    IME this has less to do with Subaru and more to do with the dealership. Good on minnetonka subaru. Glad everything worked out for you.
  17. Chaotic Yeti
    To an extent. The regional Subaru Rep was the one that came by and ok'd it. They also took pictures of the disassembled short block. Definitely +1 to Mike and the guys at Minnetonka Subaru for being on my side of the fence, though.
    spudd likes this.
  18. Chaotic Yeti
    Ok, so 400 miles in and the engine is great. Monday midday I started to hear an odd whirring noise from possibly the bell housing. It was more noticeable when the clutch was disengaged. I took note of it, and when it carried into the evening I called 'tonka Subaru to set up an appointment, as they did replace my clutch/flywheel when I had my short block replaced. Tuesday morning I heard what sounded like a piece of metal shooting around a crockpot and than dissapear. I was able to make the last hundred yards or so back to my garage with what seemed like a normal drive except for the same whirring, and again called 'tonka. I admitted I may just be paranoid, but that it did sound like it was coming from the bell housing. I could still travel through all of the gears as usual, and there was no whirring noise or otherwise at idle, only when rolling. I was told it may just be ice falling off from under the car and that unless something like that persists or escalates, I should just wait till my appointment on the upcoming Monday. Hoping that it was simply titanic destroying ice that was careening off of the bottom of my car, I drove it again yesterday. A 1 mile trip in the morning, and the same in the afternoon. The whirring was still there in the afternoon, and than......clunk...clunk, clunk, clunk... ****. I could still travel the gears, and I was able to get up my driveway and haven't touched it since. I called 'tonka last evening, and they got back to me this morning. It is gonna get towed out to 'tonka and hopefully someone can take a look at it today. My intuition tells me something was loose and snapped off in the bell housing. You could push it dead down the road now and hear the metal clunk in rythym with the speed in which you pushed it. Merry Christmas.
  19. tehfuzz
    tehfuzz Well-Known Member
    I can't say that ice would make that kinda sound and how much ice does one have to have under the car for it to keep happening very often? I get that its cold out, but I dont think that it is the case. Better to be safe then sorry and having them take a look at it. especially if it could be covered under the warranty.
    Hope this is just a small easy fix. Hope you have a good holiday, and you get back on the road with no problems!
    Cheers.
  20. Chaotic Yeti
    Definitely not ice.
    Nhibbs likes this.
  21. Chaotic Yeti
  22. spudd
    ****ty!
  23. LagWagon
    LagWagon Well-Known Member
    Wow, what a nightmare! I just bought my 2011 so I am nervous since this is my first subaru... I don't know what to expect.
    Glad to hear that Morries has been accommodating despite being tuned, I've been leaning towards tuning the car the last few days..
    tehfuzz likes this.
  24. Chaotic Yeti
    We'll see how this pans out. I hope it is related to the clutch replacement and they cover it.
  25. Chaotic Yeti
    Just got a call from Mike. They are going to have to tear it down, and I probably won't hear anything new till Monday afternoon.
  26. Nhibbs
    Nhibbs Well-Known Member
    Sounds like you have some bad luck!! Hope everything goes well and it isn't a major issue.
    Did they say they had to tear into the engine? Or just drop the tranny to see what the noise in the bell housing is?
    Or did they determine the noise was not really in the bell housing but from the engine.. :eek:
  27. Chaotic Yeti
    They seem to be really busy, and all he heard from the tech was that he needs to drop the transmission for starters.
  28. Medic_538
    MAN! This sounds like my car!?!?!?
    Did you buy it from Muscatell Subaru in Fargo?
  29. Chaotic Yeti
  30. tangledupinblu
    Good luck Tom, hope Mike gets it sorted out for ya!
  31. Chaotic Yeti
    Thanks, man.
  32. tangledupinblu
    On the plus side of things, you're going to have a new-new car?
    :coffee:
  33. Chaotic Yeti
    I suppose, I mean, the seats still seem ok...
    I dunno. Like I said I can still travel the gears smoothly, and if something was wrong in the actual transmission I am pretty sure it would be more catastrophic than this. It makes sense in my head that the issue resides in the bell housing and is related to the replacement clutch assembly they installed. If it is a new point of failure, and unrelated to anything else, I am going to be pretty dissapointed.
  34. Cotts612
    Cotts612 Well-Known Member
    Damn man. What a crapy situation. Hopefuly they figure it out quick and at no cost to you.
  35. Chaotic Yeti
    Even though my original scheduled appointment was this morning I am now told they won't be able to look at it till Thursday at the earliest. Kind of a bummer, but I understand how these things go especially with the holiday's.
  36. Chaotic Yeti
    Viscous coupler failed. Center diff had a gear tooth mosh pit.
  37. Chaotic Yeti
    Ha. The last day of my original Subaru warranty was the day I had it towed. It is all covered!
    Cotts612, Nhibbs and phi11 like this.
  38. Nhibbs
    New motor clutch and rebuilt tranny on last day of warranty. You are a lucky sob. You should buy a lottery ticket for me!
  39. Chaotic Yeti
    Lets hope this is as exciting as it gets. I am hoping for cosmic coincidence to be at it's end, and look forward to a fluke free experience from here on out. It couldn't have turned out better, but enough already!
  40. Chaotic Yeti
    Some, but not all of the parts came in today. Should be wrapped up some time tomorrow. Brand new shortblock, clutch assembly, and now a rebuilt center diff, all within 12 month warranties. Not a bad outcome.
  41. Chaotic Yeti
    Just got my wrx back home. Thanks again to Minnetonka Subaru Service Center for another relatively pain free experience. And free $ experience.
    Ryan FailRad likes this.
  42. Chaotic Yeti
    Well, 1,100+ miles on the shortblock and everything is running great. Hopefully the log of my experience helps others.
    tehfuzz likes this.
  43. gc8
    gc8 Well-Known Member
    I got nervous when I saw you bump this thread again...
    Glad to hear everything worked out. The internet is full of bad reviews, rants, and bitching; it's nice to hear some positive feedback for once.
    tehfuzz and Ryan FailRad like this.
  44. tehfuzz
    Glad to see things are working out for you again man. Hope to run into you again soon at NF :)
  45. Chaotic Yeti
    Well, it has been a year since this had all started. Car is running like a champ. I have not had any issues once these failures were resolved.
    tehfuzz likes this.
