We use the Eastwood hub style roller with a heat gun to give you a professional fender roll. This will also give you about 1/2-1" extra fender space or flare. You must contact me to set up an appointment, price for each fender is only $50!
Business name and operation has changed. It is now called Proller, and I will be running solo for onsite rollings. 1. I will only do onsite rolls at a place you decide on. outside temp should be minimum 60 degrees outside, if between 40-59 degrees, you must have a good size garage, so my heat gun can work properly. or if you don't care about paint chip, then disregards. REMINDER!!! SUBARU PAINT IS VERY CHEAP NO MATTER THE MODEL OR YEAR! It will likely chip! 2. Your car must be jacked and tires off on fenders that are being rolled. 3. Time scheduled are very strict! More then likely if rescheduled it'll be another 1-2week block. 4. Usually will take 20-30mins per fender. Prices will vary, since I'm no longer able to do it my place. If it is within 10 miles of north central Oakdale, I will only charge $40 per fender. And $50 for anywhere else pass 10 miles to maximum 30 mile radius.
