Left front wheel noise: Thoughts on culprit(s)?
Discussion in 'Modifications And Maintenance' started by Soupboy, Oct 12, 2008.
  1. Soupboy
    Soupboy Well-Known Member
    Developed some whining/howling/rubbing coming from the left front wheel today at the end of the fun run. Most noticeable when turning right.
    Bill already suggested a wheel bearing as a suspect. 07 WRX wagon, 32k miles, never tracked/Auto/Rally/Xed. 95% freeway cruising miles.
    Thanks in advance
  2. Paul Revere
    Did you put it in reverse to shake out any possible rocks on the caliper?
  3. piddster
    It might go away if you clean some of that fail out of your car.
    But seriously, it could be a wheel bearing. Its kind of hard to say what it is without hearing it myself, but what you describe hints at a bearing.
    Does the sound change with speed as well?
  4. Soupboy
    Duly noted. I told Chet he couldn't ride shotty.
    Si, frequency and pitch/tone change with speed.
  5. piddster
    Hmmmm. You can has warranty?
  6. Soupboy
    Yeah. It will be heading to Tonka Subie soon. Just curious if someone could eHouse it for my sorry ass.
  7. piddster
    Meh, my shaggenwagon has a couple of howling wheel bearings. I've just been too lazy to fix them. They are annoying though.
  8. tonyM
    I would say wheel bearing as well. although it is kinda weird it doing it with the little bit of wear on the car.
  9. Soupboy
    The sound really comes on when the car is laterally loaded in a RH turn. Suppose I can avoid it by e-braking and counter steering every RH turn...
  10. piddster
    Sounds like a winning plan to me. Watch out for the fuzz though.
    Are you sure its coming from the right side? It can be really tricky to tell sometimes, and I've been fooled before thinking it was from one side when it was the other. Shops usually have a stethoscope thing and the put a transducer on all the hubs so they can listen to them and compare. I forget what its called.
  11. Squiggly
    Squiggly Squiggly
    i had a loose axel nut recently that was fixed by retightening with an air tool.
    everything sounded similar to what you were explaining
  12. TSTRBOY2004
    yeah typically it is the opposite side of which way you are turning.....
    I owuld look at it for you, but apparently last time we exchanged on this forum you said I was brain-dead so I guess I have no ability to diagnose it for you ;)
    Warranty should take care of that for you though... ;)
  13. Soupboy
    Sorry if I wasn't clear. The sound appears to be coming from the left front wheel and is most noticeable in RH turns. Thanks everyone for your feedback.
  14. TSTRBOY2004
    yep.. sounds like a bearing then... especially seeing as it would be loaded when turning the opposite way.... (typically anyways)
  15. AWDimprezaL
    that would sound like a wheel bearing to me also, maybe it was on its way out and got pushed over the edge on the fun run.
  16. Soupboy
    Hmmph. Is there a "typical" amount of use when one can expect seeing this or might I just have a bum bearing? I put almost 60k on my 02 WRX wagon and it required nothing other than oil and gas...
  17. TSTRBOY2004
    joy of cars my friend.... its like some guys get all the hassles and others have dream cars that never fail....
    its a part that rotates a lot and fast.. some give up the ghost quicker I guess... all it takes is a small deformity in one of the bearings inside to pre-maturely wear something out... and soemtimes y ou can drive another xxxxxxxK before it breaks.. but dont.. ha ha
  18. Motorhead
    Motorhead Well-Known Member
    Cat Killer
    He probably just hit the neighbors cat who is probably still stuck to the sway bar since this is the only way he can get any p*ssy. Could not resist this one!
  19. TSTRBOY2004
    maybe you should have...
  20. Soupboy
    I'd never run over a cat, but I shoot the sh!t out of one!
  21. Soupboy
    Jason is my *special* friend. He is not wise in the ways of this here innarwebzhole.
  22. angusracer
    angusracer Well-Known Member
    i have this problem as well. it originally came from a loose axle nut, like 2.5rs said. but since i listened to everyone on this forum i changed out my wheel bearing for nothing, and tore my cv boot in the process. now i have a whole new mess of problems. coulda been fixed by a simple tighten.
  23. TSTRBOY2004
    well.. listening and getting someone who actually KNOWS what they are doing are 2 different things... what else you expect for blindly following e-fixes
