Legacy shaking
Discussion in 'Modifications And Maintenance' started by whipsack, Dec 16, 2008.
  1. whipsack
    whipsack Well-Known Member
    My car now decided to start shaking above 30 mph or so. The faster I go the worse it gets. What's up?
  2. Gridlocked
    Snow or ice in the tires or loose lugs?
    Get a good long car wash with the side blasters and see if that helps.
  3. whipsack
    I'm not so sure it is snow or ice, I had a similar problem last winter and it was snow in the wheel wells.
  4. silver03
    ^^Same here.
  5. predavore
    predavore Well-Known Member
    Flat spot from sitting? Does it go away when the tires are warmed up?
  6. whipsack
    No, no change.
  7. predavore
    My money is on snow/ice in the rim. If your tires are warm and water gets in there. It can freeze when the rim stops. It doesn't take much to throw off the balance. Take it to a car wash and blast the crap out of the rims. Get them clean and try again.
    Or you threw a weight.
  8. whipsack
  9. gc8
    gc8 Well-Known Member
    They were great to deal with. Granted I had a few issues (probably my fault anyway) but they took care of me. Great guys over there...definitely recommend them!
  10. BoBo82
    BoBo82 Member
    happened to my old legacy when i drove in a bunch of snow. snow boogers and stuff get stuck in the wheel wells and other components and it feels like something is wrong. drive over some bumps, drive faster, or hit the car wash and it will probably go away.
