lift my wrx
Discussion in 'Modifications And Maintenance' started by scrltspedstr, Oct 28, 2012.
  1. scrltspedstr
    scrltspedstr Well-Known Member
    so i have looked around and found many contradictory thread on sites.
    i would like a simple and inexpensive way to lift my 04 wrx sedan for the winter
    i have been reading up on replacing mine with forester springs and struts.
    read that this can be bad on cv joints and axels, also read people run it for years without problems
    i think i would need trailing arms too
    or can i just run 1" spacers and have that work.
  2. Shancaldazar
    Well... how much are you looking to lift the car? 1 inch? 6 inches? Taller than your redneck neighbor?
  3. Soupboy
    Soupboy Well-Known Member
    Current ride height? Good gracious why? Buy some taller, narrower snowies and put them on Steely Dans?
  4. scrltspedstr
    just a bit not too much just enough to help put in the winter 1" works 2.5 is great if the forester suspension works
  5. DIRTY D
    DIRTY D Well-Known Member
    I would like to do the same but I would go for some nice coilovers and adjust the height for summer and winter. I should of bought smaller winter tires and wheels but too late. I was looking at the 1" spacers but coilovers would solve more than just height.************D
  6. issues
    issues Well-Known Member
    So one thing these lifting threads never go over is how do I relieve the stress on the drivetrain by screwing up all the driveshaft angles.
  7. scrltspedstr
    yea i dont want to stress stuff too much.
    i was reading about the front end spacers that foresters have that raises the whole assembly.
    i read coil overs are not a good idea because you would be essentially riding on the maximums for the whole time lifted up adn lowered down.
    I'm running a 225 45 17 for my winters just looking to clear snow piles. a big chunk of ice broke the lower part of my last bumper cover a few years ago.
  8. xluben
    Most of the cheap coilovers out there will NOT raise the car, even at their highest setting. BC's are still lower than stock, even when you raise them up all the way.
  9. gc8
    gc8 Well-Known Member
    Where are you driving that you need to lift your wrx?
  10. scrltspedstr
    just wanna be above the snow in front
  11. svxninja
    svxninja Well-Known Member
    Well depends on where you live out in the boonies? Because most of the snow is plowed in the metro, you shouldn't have a problem if your at stock height
  12. Subie Lovers
    Angles involve math... Didn't you know this forum uses science not math???
    ofspunk7 likes this.
  13. yarpirate
    yarpirate BANNED
    Even up in St. Cloud (which may be considered the boonies, I guess :p) they are really bad about actually plowing. It's not uncommon to have to go through a foot plus of snow on my way to work, if I chose to drive rather than walk. In that event, it's pretty easy to bottom out and teeter totter. Current car is lower than stock height - hopefully won't need to, but I have springs (thanks again, idget) that should bring it back to normal should I need it...
    Have you had problems with ride height during previous winters? If not, I'd say just leave it the way it is. Just put snow tires on and get a cheap front lip to use as a makeshift plow! You can charge your neighbors to clear their driveways.
    DIRTY D likes this.
  14. Roboduck
    Roboduck Active Member
  15. J.Rex
    J.Rex Well-Known Member
    The higher the ground clearance, the deeper you go into the woods, the more stuck you get, just something to think about
  16. DIRTY D
    I like the idea of a custom bumper that can push the snow out of the way. Mine has a crack in it from two years ago but it still is hanging on. Maybe this spring it might be time for a new one. I get by but it just takes one ice chunk and out comes the duc tape.
  17. svxninja
    I know what you mean my girlfriend has a cabin on Pearl lake, it's kind of fun
  18. Subie Lovers
    Funny thing is, the last time I seen your girlfriend I left her with a Pearl Lake... She thought it was kind of fun!!!
  19. yarpirate
    yarpirate BANNED
    02_Rexxxy and Subie Lovers like this.
