light mods
Discussion in 'Modifications And Maintenance' started by scrubaru, Oct 14, 2012.
  1. scrubaru
    scrubaru Member
    Can I run A catback exhaust without doing a tune? And can I remove the intake silencer? This is all on a 04 sti
  2. Shane86
    Shane86 Well-Known Member
    yes and yes.
  3. scrubaru
    scrubaru Member
    Sweet thanks much.
  4. ScaryFatKidGT
    ScaryFatKidGT Member
    3" exhaust, then either and intake or if you just pull the silencer get a better air filter. Also a light weight crank pulley. If you drive hard don't forget break pads.
  5. scrubaru
    scrubaru Member
    I'm doing cat back for now to get a better sound then after I save some money I will do the dp and up then a tune and the dealer just did new rotors and pads
  6. SkeetsWisconny
    Sounds like a start.... catback alone will not really gain you power alone in case u did not know. I did the opposite - dpipe and accessport map first. (If you do dpipe your sound will change, most especially with a catless) Than later catback.... than more. Your wallet best beware once you begin. Enjoy.
  7. scrubaru
    scrubaru Member
    Yeah I know its not a cheap car to mod lol but Its worth it lol
  8. Nuke
    Don't grab an intake without a tune.
  9. scrubaru
    scrubaru Member
    I have heard an intake isn't worth putting on?
  10. tangledupinblu
    Not really. Depends on if you are talking about a CAI or a SRI. The SRI like to heatsoak all of the air from the engine bay. The CAI you definitely want a tune for!
    If you remove the silencer, hacking the 180 degree elbow off and using it to pull from the stock air intake location is a plus IMO. It's pretty easy to do and you are basically still running stock air in, minus the silencer bellow.
  11. scrubaru
    scrubaru Member
    Sounds good I will soon gather parts then do tune and put them all on. For now I just want the sti sound from the catback and yeah I watched a DIY on YouTube about the silencer prob doin that tonight
