lights
Discussion in 'Modifications And Maintenance' started by jing123, Mar 24, 2008.
  1. jing123
    jing123 Well-Known Member
    any ideas on how to aim the lights because one of my lights is to low and the light beam isn't concentrated at the right place any help would be appreciated since i just got hids to so yea
  2. Sky58
    Sky58 Well-Known Member
    What year you have?
  3. jing123
    2001 rs coupe.
  4. jing123
    any ideas
  5. StartRestart
    On the reverse side there are two bolts heads that stick out, one tips it up and down, the other turns it left and right. 8mm i think and you don't have to turn them too much.
  6. jing123
    alright thanks ill try that tomorrow
  7. LittleMissJackStand
    LittleMissJackStand New Member
    What i did to align mine was park on my drive way and I used the horizontal lines on my garage door to make sure they were aimed at the same height.
  8. Paul Revere
    Did you measure from the ground to the circular dot on the lens?
  9. NMDAYTIME
    NMDAYTIME Well-Known Member
    i did the same but then i got pulled over by a cop saying my headlights were too bright.
  10. jing123
    lol i tried a few times and they didnt move how many times do u have to turn the screw
  11. StartRestart
    I notice a difference in a 1/4 turn.. look at your levels that are installed on the back side of the headlights. If not something is probably broken or stripped off the tracking, ishy.
