Is there any local place that makes stainless steel line with banjo bolts? I need a new oil feed line for my07wrx. It seems like the 07wrx and 07sti's use the non-avcs lines and does not feed to the avcs.
You can usually put something together with Aeroquip stuff for $50 or less. FBC (teflon lined) hose and steel fittings. If you don't want to order it, Power Systems in Chan or Air Hydrailic Systems in Plymouth should be able to set you up. http://www.aeroquip.cc/aeroquipsae37degreemaleflaretometricbanjoracingadapters.aspx http://www.aeroquip.cc/fcm1102-fbm1102.aspx http://www.aeroquip.cc/fbc0400fcc0403-3ftlength.aspx
