Logging with Cobb AP V1 Cable?
Discussion in 'Modifications And Maintenance' started by Kosh, Mar 4, 2012.
  1. Kosh
    Kosh Well-Known Member
    Does anyone know if it is possible to use any of the open source programs like romraider to log with a V1 AP Serial Cable? I tried hooking it up, but it didn't connect with romraider. If the Cobb cable won't work is there a cheaper alternative than a tactrix cable? Just want to log, not tune.
  2. BroCo
    BroCo Well-Known Member
    St.Francis Minnesota
    Check out the BFM cable on Ebay. I have one and it works just fine.
  3. JasonoJordan
    The bfm cable only will log on a 02-03 wrx not flash just a heads up
  4. Kosh
    This would be on a 2006 STi. Should have mentioned that.
  5. BroCo
    It will work just fine then. I also should have mentions 05 STI
  6. JasonoJordan
    also i have a spare cable if you just need a log u can borrow. pm me if u need to.
  7. Kosh
    Good news, I set my comm port to 4800 baud and ecuexplorer worked.
  8. xluben
