Logging
Discussion in 'Modifications And Maintenance' started by Skarecrow, Jun 1, 2008.
  1. Skarecrow
    Skarecrow Well-Known Member
    ok tuning guru's
    I just got the new rom-raider version and plan on doing some data logging, to do some tuning.
    Mods since last tune:
    inlet
    manifold
    up-pipe
    is there anything specific that I should be logging so I don't overload with stats?
    enginespeed
    feed-knock
    fine learning knock
    IAM
    AF correct
    AF learning
    manifold pressure
    mass air
    timing
    wastegate
    throttle
    turbo burst
    turbo continous
    that a bit much or does that sound about right?
  2. TSTRBOY2004
    did ya read the setup on the romraider forums or the OSEcu forums.. they give the base run down...
    I have them saved somewhere.. looked cant find it..
  3. Skarecrow
    trying to rifle through it
  4. Bullwinkle
    For typical 32bit ECU tuning, I log the following:
    Air/Fuel Correction (%)
    Boost Error (psi)
    Engine Load (RAM) (g/rev)
    Engine Speed (rpm)
    Feedback Correction (degrees)
    Fine Learning Correction (degrees)
    Ignition Timing (degrees)
    Intake Air Temperature (F)
    Manifold Rel. Pressure (Corrected) (psi)
    Mass Air Flow (g/s)
    Primary Wastegate Duty Cycle (%)
    Throttle Opening Angle (%)
  5. TSTRBOY2004
    knew one of the freaks ;) would chime in soon.. ha ha
  6. Skarecrow
    what I was hoping for :)
    thanks bud
