Long winter warm up?
Discussion in 'Modifications And Maintenance' started by thentro, Jan 23, 2009.
  1. thentro
    thentro New Member
    Hi everyone, I thought I would ask this here because everyone knows what I mean by "cold" on here ;)
    My question is, how long should it take for a normally aspirated 2.5L engine to reach operating temperature in the winter? I live in St. Paul and have a 02' Impreza 2.5 with 127k miles on it and have had it since last spring, but I suspect that its thermostat might be stuck partially open all the time because it takes a long time to reach operating temperature and for the heat to get hot. The thermostat was replaced at 112k miles before I bought it, along with the head gaskets and water pump. Perhaps I am just cold and want to blame the car?
    Thanks
  2. AWDimprezaL
    It will have lots of different variables. Mine has recently been a bitch to get warm, even with a new stat.
  3. tonyM
    I just got a new t-stat but it takes the exact amout of time to warm up as before.
    but then again, I let it warm up about 30 minutes every morning. so it could be quicker, but i dont think so.
  4. sneefy
    sneefy Well-Known Member
    I have an N/A 2.5 and it takes a long time.
    You can try one trick, start the car and let it idle for 5 minutes (or more) with the fan off. If it's not sucking heat from the engine bay to heat the cabin, it will let the engine warm up a little bit faster.
  5. Aegis
    30 minutes is a long time! - i let mine warm up for 15 mins when it's very cold, and it's usually toasty by then. Jason's car takes longer of course...
    I do the shut the fan off trick for the whole time, then when I get in the car I i just turn on the heat. My commute is 10 minutes max though :D
  6. manochromatic
    manochromatic Member
    99 2.5rs takes me 10-15 minutes for operating temp..more around the 15 minute mark,but it takes roughly 30 minutes for the heat to be really warm.
  7. hella_sti
    hella_sti Well-Known Member
    30 min?! Holy crap, try sticking a piece of cardboard inbetween the outside and the radiator and it'll heat up faster. Try a bit of brake boosting on the highway, that usually helps, hahah. My 03 wrx heats up in 5 min driving it in -20 degrees with a 5-8 min warmup at idle.
  8. qstarin
    qstarin Well-Known Member
    My 01 2.5RS warmed up pretty quick (10-15) minutes when it had an auto tranny.
    Now that it's a manual, it takes about twice as long to reach temp when its below zero.
    Of course, these time are with my heater on full hot with the fan on 2 of 4.
    If its still cold after 1/2 an hour, that's probably something wrong. But if its just not as hot as it is after driving it a bit, I think that's within the realm of normal.
    Also, is your heater on when your warming it up? That will of course make it take longer to warm up
  9. Soupboy
    Soupboy Well-Known Member
    10min for 07 WRX w/ fan running. Also, heated seats!
  10. sniper1rfa
    sniper1rfa New Member
    Won't really help, since the coolant doesn't start circulating until the motor warms up some anyway.
    Mine takes about 10 minutes driving to start warming up if i forgot to plug in the block heater. Warm by the second stoplight if i don't forget. :)
  11. webcrawlr
    webcrawlr Well-Known Member
    You said it. That'd suck!
    I give the car about 30 seconds to "warm up" then start driving and about 5 minutes later the blower kicks in and starts blowing warm/hot air. I can't imagine waiting that long...
