Looking for good website for 02 wrx rear upgraded axles. I have a rwd conversion and would prefer 600hp rated at least. Rallysportdirect and driveshaft shop do not have bugeye rear axles..unless I missed it. Wanna keep it around 500$. Also want to do hawk eye front end conversion. White preferred. Call or txt or reply on here 920 573 1431 thanks
You still have the R160? If so here you go: http://www.driveshaftshop.com/import-axles/subaru/subaru-rear-axles-500hp-rear-axles-all-years I would reccommend upgrading to the R180 too if you are sending all the power through the rear. If you do that you need these: http://www.driveshaftshop.com/impor...c8-except-type-r-ra-500hp-rear-axle-r180-rear I have the R180 conversion rear axles on my car and they do the trick! A little spendy tho.
DSS has them.... The Driveshaft Shop | SUBARU 1992-2001 Impreza WRX / 2.5 RS (GC8) / 2002-2003 WRX (GD) Sedan 750HP Level 5 Front Axle Set - Import Axles http://www.driveshaftshop.com/impor...preza-wrx-2-5-rs-gc8-750hp-front-axle-level-5
