Low oil level
Discussion in 'Modifications And Maintenance' started by pho_real, Feb 6, 2013.
  1. pho_real
    pho_real Well-Known Member
    Need some input here. So this morning I checked my oil after the car was warmed up to temp. and the oil level was really low. I use Amsoil for my oil with an OEM Subaru filter and I have a stage 2 setup. The oil was only changed 1500 miles ago. Any reason for why the oil got so low this quick? I've always used Amsoil and this has never happened before.
  2. JasonoJordan
    How many miles on the car. What kind of car is it so on so forth general information to help us help you....
  3. Jerf
    Jerf Well-Known Member
    For one you should check your oil cold. 2, do that and see what happens. It takes a good 3-5 mins for the oil to run back to the pan, so the level will be incorrect if the car was just running.
    pillboy likes this.
  4. pho_real
    Sorry, just remembered that I was missing the mileage info.
    Car is an 04 wrx with almost 80,000 miles.
  5. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    This. Make sure you're comparing apples to apples. Having just gone through this, advice I received was first make sure I'm accurately measuring everything, as just discussed. If definitely losing oil, how much? Pull the intercooler to check for excessive blow by. Compression test if it's confirmed suddenly losing more oil than you're used to.
  6. pho_real
    I guess you could say I am losing more oil than I'm used to since I did change my oil only 1500 miles ago.
    I'll try and check my oil tonite when I leave work and see what the level is at since the car will have been sitting for a good 6+ hours.
  7. SurlyOldManMN
    Most importantly... is your car black?
    BroCo and ShortytheFirefighter like this.
  8. ShortytheFirefighter
    If you checked your oil with the engine running it's going to look like you're low on oil. Check it cold before you worry about losing oil, odds are you're just fine.
  9. tangledupinblu
    ^And don't add any oil until you do!!!!!!
    Jerf likes this.
