Indeed they do. Passenger Lower Control Arm - 2002 WRX Wagon - 130,000 miles. Check out my bad phone pic: There is a bit of corrosion there. Any hot tips on replacing one of these?
All I can say is, OH SNAP! Heheh, really the hardest part is getting the ball joint off the control arm unless you get a new one of those too.
Ball Joints are a pain. I replaced one two months ago and when I had to pull the hub last week it was easier to wreck the old one and replace it than try to get it out nicely. If it's an original at 8 years old I would not even consider being able to reuse it.
That is correct, New ball joint, and Bushings $198.26 No stock, Two days on a stock order. The biggest pain i would plan for is the OLD ball joint release bolt being a PITA.
Oh yeah, I have been hitting that bolt and others with PB blaster since this morning. The part is already on order, hooray for the MNSOC discount!
