Mad Dad electronic boost gauge problem.
Discussion in 'Modifications And Maintenance' started by Bnuts01, Feb 26, 2012.
  1. Bnuts01
    Bnuts01 Well-Known Member
    I bought a bunch of these subaru parts from this guy and it came with 3 Gauges (2xboost, egt). So I am hooking up one of the boost gauges and I had a diagram that told me what 4 wires I need for the power/light/ground/etc source. I turned the ignition on it sweeps zero's out and stays there. I put all my vacuum line in and attach the sender unit to the vacuum and then to its main supply. Now when I turn the car on it sweeps, zero's, jumps back to 30PSI and sits there.
    Could it be the sender that is my problem? Because if I unplug it, it stays at zero once it is plugged in it jumps to 30.
    Or am I pushing 30psi at idle?... :dodgy:
  2. JasonoJordan
    sounds like a sender isse have u tried the sender with ny of the the other guages to double check or is it a different plug style
  3. Bnuts01
    I tried the other boost gauge and it still sweeps and jumps right to 30psi... Now I have to find Mad dad's number.
  4. Bnuts01
    Well I found a e-mail hopefully he can write me back...
  5. JasonoJordan
    deff sounds like its the sender
  6. issues
    issues Well-Known Member
    MNbugeye mafia #651
    naw 30 psi at idle is normal;)
    Bnuts01 likes this.
  7. Bnuts01
    O good! I was scared for a bit!
