Metal Shavings behind timing cover?
Discussion in 'Modifications And Maintenance' started by Mitchum, Sep 4, 2011.
  1. Mitchum
    Mitchum Well-Known Member
    After recently acquring a 01 RS sedan with a wicked noise that's coming from the top end i'm guessing, i removed the timing cover to find metal shavings generally all around the crank/timing belt area. Has anyone ever seen this before and come up with a conclusion as to where the failure occured and for what reason? Sorry if I havent given enough information, plan on digging a little deeper into in tonight. Thanks
  2. Threshld1
    Threshld1 Well-Known Member
    A picture would help a ton. Without seeing anything I would guess one of the t-belt idler bearings is toast.
  3. carl
    I would also think most likely from one of the idler bearings
  4. Mitchum
    i'll have some pictures posted tomorrow.
  5. jas3087
    jas3087 Well-Known Member
  6. AWDimprezaL
    There is no way that car would run with that many teeth off, it sometimes takes MANY revolutions of the T-belt to ge the marks to line up perfectly, get a new idler, put it on, and re time it, you'll know right away, when it wont idle.
