MFactory gears ?'s
Discussion in 'Modifications And Maintenance' started by Paul Revere, Mar 8, 2008.
  1. Paul Revere
    First off anyone other than Sheen heard of these guys? I found them on RS25 today, they seem to make a lot of Honda stuff. Also I want to make sure I did my calculations right with the gearing. Pricing starts around $2300 for 1-4 and $2550 for 1-5, seems like a good deal if we only knew what kinds of numbers these hold up to.
    http://www.teammfactory.com/products.php?category=Close%20Ratio%
    For gearing I used http://www.f-body.org/gears/
    Tires - 225/45-17
    Axle Ratio - 3.9
    Redline (RPM) - 7000
    1st - 3.270
    2nd - 2.286
    3rd - 1.667
    4th - 1.238
    5th - 0.958
  2. Nuke
    They can hold a good amount of power, but do you plan on tracking your car?
    The gearing sucks for daily driving. They're very short and almost the same as KAAZ gears.
  3. readymix
    Is axle ratio your final drive? If so, yours probably isn't 3.9, unless I'm mistaken on that one. I was under the impression that WRX FD was 3.545.
    Also, either way, those ratios are really short, prepare for cappy gas milage.
  4. Paul Revere
    Thats what I noticed 70 in 5th is 3500 stock gearing is 2700.
  5. Paul Revere
    Pulled the final drive from this website http://www.cars101.com/subaru/impreza/wrxsti2004.html#mechanical
    How are the RA gearsets for mileage and wear and tear?
  6. readymix
    RA gearsets aren't any better than the 04 gearset really. IIRC, the gear widths for the 04 and the RA's were the same. I could be wrong on that too. I'd check nasioc if you want the real scoop. Check the tranny FAQs. The RA's are shorter ratio though.
  7. AspitFire
  8. idget
  9. StatGSR
    StatGSR Well-Known Member
  10. FuJi K
    The MFactory 5th gear on a 3.900 is compareable to the STi RA's 5th on a 4.444 final drive on the hiway. Take these over STi RA's.
  11. EK6hatch
    EK6hatch Well-Known Member
    MFactoy+Honda=Good
    MFactory+Subaru=Good
  12. idget
  13. AspitFire
  14. idget
    small group buy
