Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. badbennyb
    Yep, them are nice guys there.
    I should have some goodies coming including IC sprayer nozzle, forester temp gauge and a few misc clips, lemme know if/when I may pick up.
  2. AWDimprezaL
    Yep, said items are here.
    phi11 likes this.
  3. Dirtyracin
    Dirtyracin Member
    I called my subaru dealership and they wanted my vin# for 09 struts..... well I have an 08 and wanted to do the 09 upgrade so I have no vin# for said struts but its an 08 sedan wrx non-premium. I heard the 09's are better and if this is true a price qoute on struts.
  4. Dirtyracin
    Dirtyracin Member
    ignore that I just called
  5. badbennyb
    Thank you sir, I'll swing by tomorrow afternoon.
  6. G_2.5rs
    G_2.5rs Well-Known Member
    Looking for the following items for a 99 rs.
    Full radiator core support
    RS Hood only
    Passenger side headlamp
  7. Bielke55
    Full radiator core support - Cant get it as an Assembly. The total for a upper tie bar, hood latch support, RH and LH Support panels, both lower supports, and radiator brackets is = $326.30 (7 pieces total)
    RS Hood only = $295.96
    Passenger side headlamp = $151.96
    I dont have these parts in stock. I would need to order them.
  8. Drocnoc
    Drocnoc Well-Known Member
    2x - 2004 Forester Trailing Arm Brackets
    2x - 2004 Forester Rear swaybar mounts
  9. MidnightImpreza
    I need to purchase a new driver side sun visor for my wife's 08 2.5i wagon. It lost it's spring and won't stay up anymore. I'm wondering who I can contact at any of the dealerships for this 20% discount? Thanks.
  10. predavore
    predavore Well-Known Member
    Happened to my 08 wrx too. Must be a bad design. It won't go up all the way to the glass. If you push it up there, it will break. I got mine replaced under warranty luckily.
  11. Bielke55
    $25.26 each, For the trailing arm bracekts
    $11.34 each, For the Sway Bar Brackets
    Neither in stock, need to order. 2 days on normal stock order.
    We stock those visors because its been a known problem. Not sure what subaru is doing about it, But the a new visor is an updated part.
    $55.42
    Just let someone know your with MNSUBARU, and you will receive the discount.
    Yea they updated the visor so hopefully the problems are fixed.
  12. Drocnoc
    2004 Forester Front Strut Dust Cover
    2004 Forester Rear Strut Dust Cover (are there clips that hold these in or anything of the sort?)
    2002 WRX Upper Radiator Hose
    2002 WRX Lower Radiator Hose
  13. MidnightImpreza
    THANKS! It's the tan color interior, and I'll be calling later this week to make my purchase. Thanks again!
  14. slacker
    slacker Well-Known Member
    hello! i would like to ask how much are there following parts: '11 WRX SPT Exhuast (4dr) Also, labor costs. Thanks in advance!
  15. GinNam
    GinNam Well-Known Member
    Hey, how much would a rear quarter panel for a '97 Coupe cost?
  16. GinNam
    also., how much would the rocker panel cost? thanks.
  17. SurlyOldManMN
    How much for a grab bag (4-6) of 2010 legacy gt "top" engine cover pop-it thingers?
  18. Musashi
    PM Sent with inquiry.
    Many thanks!!!
  19. G_2.5rs
    looking for the 00-01 rs bumper with the lip mounting holes on the bottom.
  20. Mr.Tran
    Mr.Tran Well-Known Member
    Are you guys still selling extra-s in quarts?
  21. Goalie
    Goalie MNSubaru Goaltender
    Do you guys have engine flush in stock? The stuff that goes in the oil to clean out old nasty stuff. I'm assuming it's something the service guys can add if I come up to get an oil change.
  22. Bielke55
    Yea we do stock it now. $15.99 for the bottle, you'll have to ask service about there ways of doing it. Every tech does it differently.
  23. Goalie
    Cool thanks. I called and scheduled. What are the synthetic oil options? the guy on the phone wasn't sure.
  24. Chipster
    Chipster Active Member
    Hello... Do you guys have any extra-s? I need 4 quarts.
    Thanks!
  25. Bielke55
    Yes we have some in stock
  26. Drocnoc
    Group N 5MT trans mount and cross member bushings for MY02 wrx?
  27. AWDimprezaL
    Turbocharged spark plugs are NOT THE SAME AS N/A. Leave the mechanical part of cars to the people who know what they are doing.
    phi11 likes this.
  28. silver03
    I'll be in tomorrow to grab my spring and shifter bushings. thanks Rick
  29. freeze2104
    freeze2104 Well-Known Member
    first time seeing this thread! my wrx(black 04) is there now getting my rear brakes changed... anyway to still take advantage of that 10% discount :angel:?
  30. Bielke55
    Did you pick up already? Whats your full name?
  31. 054eatwagon
    054eatwagon Well-Known Member
    do you stock , and how much for all the rollers/idlers(?) for the timing belt stuff , i already have the new belt and tensioner , my car is a 05 wrx , thanks
  32. Bielke55
    Two smooth idlers = $59.96 each
    One cogged idler = $63.10
    One small idler = $65.46
    All in stock
  33. 054eatwagon
    Thanks , I will try to come get them Saturday.
  34. fancyfootwork15
    Do you have any rear sway clamps and endlinks for 08-10 wrxs? Thanks in advance!
  35. Bielke55
    Clamps are $3.16 each
    Links are $46.02 each
    Neither are in stock. Gotta stock order them. 2 days
  36. curly2k3
    gas filler neck, I gotta check again if its the 93-97 or the 98-01 version... wagon itself is a 98, I can get the vin if it helps too to get the right one (stupid 98's have been troublesome to get the right parts for before).
  37. freeze2104
    do you stock any jbp sti front bumper splitters? if so how much?
  38. Bielke55
    Not in stock, Need to order them. $67.78 each already painted. 2 days on a stock order.
  39. V8HAHA
    V8HAHA Active Member
    How much for a 2004 wrx clutch fork spring? thanks
  40. sneefy
    sneefy Well-Known Member
    Need a key/remote cut and programmed for a 2009 legacy 3.0R. Price please for key and programming labor? Thanks!
    (One of the slimmer 2009 keys with built in-remote.)
  41. sneefy
    SO, my car threw a P0420, I went to a FLAPS to read the code, and they cleared it. Do I need the code there in order for you guys to diagnose? Car is still under bumper-to-bumper warranty.
  42. Bielke55
    $4.70 Not in stock
    $62.36 for the key/remote. Programming is $59.95
    Yea that I dont know. I know they need to have a complaint that they can prove to Subaru. But most likely with that CAT code you'll have the CEL come back on.
  43. sneefy
    That'll work. When can I come in and how long should it take?
    Yeah, that's what I thought. Hopefully it will come back before the bumper-to-bumper runs out.
  44. sneefy
    edit, double post!
  45. mn63
    mn63 Member
    How much would I be looking at to have you guys do my clutch and or Right front wheel bearing. Its on an 02' WRX wagon. I got the car about 6 mo. ago From Morries in BC. They added a 2 yr or 24,000 Mi Warranty.
