Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. MikeO
    MikeO Active Member
    Good to know - thanks.
  2. John16V
    John16V Well-Known Member
    00's RS front and rear brake pads have them in stock?
    Last four # of my VIN 5737. thx.
  3. driftin240
    driftin240 Well-Known Member
    We have them in stock. $144.75 for front and rear including tax.
  4. i_subie
    i_subie Well-Known Member
    driftin240 - could you look up how much it is for a 98 RS, IAC and does the gasket piece come with it? PCV Valve, and front and rear 02 sensor. That should be all.
  5. driftin240
    That stuff ain't cheap. $508.49 w/tax for Both 02 sensors, and the IAC and gasket. I have a few PCV's lying around...so i'll hook you up with one.
  6. i_subie
    damn...you gotta be kidding me. 508.49 for all that stuff that's also with the 20% right? hmmmm...i got a different result from subarugenuineparts.com...>_<
  7. driftin240
    That's what the computer says. That Idle Air Control valve isn't cheap. Unless you were talking about some other IAC????
  8. i_subie
    I've checked at autozone and it's $309.xx for the IAC and then I checked at our local Subaru dealership and it cost $311.xx then I called in at the BP Subaru and this lady said that it's $311.xx but with the 20% it's around $249.xx. I also know that the 02 sensors are costy.
    But a little off topic. If the rear 02 sensor messes up and if the front 02 sensor is still okay, it's not a big problem right? or does it still make the car eat up a lot of gas?
  9. driftin240
    It can effect your driveability.... and how do you know that it's just the rear one that went bad.
  10. driftin240
    The IAC, with the discount, is $249.30 and the gasket is $4.24. Those do not include tax.
  11. i_subie
    Because CEL came on, used OBDII code reader thingy, had my CEL papers, looked it up and it says rear 02 sensor but it not important.
    IAC will be fine I'm guessing but what's the price on the front 02 sensor, including tax, and with 20% off. I f'en seriously need one because i get like 15mpg city!!!
  12. ScandiaWRX
    Drifter 240 - Does BP Subaru have a stock fog light switch assembly for an '06 WRX Wagon in stock?
    How much are they w/ MNSubaru discount?
    I'm adding a light bar and want a 2nd stock switch to trigger the relay for the 2nd set of lights.
    My Dad should be in for the warranty radio replacement on his '06 Legacy Wagon as soon as the new one comes in. Maybe I can get him to pick this up for me if you have one. I'll remind him to ask for MNSubaru club discount.
    Thanks, Amy
  13. AspitFire
    how much again for the exhaust gasket that goes between the manifold and the up pipe? also can i pick this up at morries in bp for the same price?
  14. Dynapar
    i am looking for a bottle of touch up paint. curious on price, and availability. its hunter green. i will check the paint code later tonight (307 IIRC, not sure though)
  15. driftin240
    Brooklyn Park shows that they don't have one. I don't have one here either.
    $24.37 w/tax
  16. driftin240
    $7.50 w/tax. We have a few here, and yes the code is 307.
  17. Dynapar
    ^awesome! what hours are you open.
  18. driftin240
    mon-thurs 7-7 fri 7-6
  19. Dynapar
    well i will try to get in there fri some time. as i can make it during those hours any other day :-p
  20. sapalas
    sapalas Well-Known Member
    Over the weekend my windshield washer died, The pump is ok i believe and we think there is a short in the wiring. At least thats what the multimeter told us.
    I am planning on bringing it in to get looked at. and wanted to know if you could give me an estimate of how long (hours?) it would take to go through the wiring to find the short or other cause for the washer not to work.
    Need to try and plan ahead around work.
    thanks,
    Shaun
  21. AWDimprezaL
    no idea, that would hafta be sorted out through the service dept, you said the motor is working? can you hear it? its probably iced up
    phi11 likes this.
  22. sapalas
    i am assuming the motor is working cause i bought a new to replace the oem one and the new also made no sound, that is why i am assuming it is in the wiring or maybe the switch.
    when we put the multimeter to it we got a reading of about .06V to the front motor compared to 22 or 11V (cant remember) when checking the rear motor.
    (i have a wagon).
  23. driftin240
    22v, I think not. 12v possibly, but not 22v. That sounds like you have a bad switch. Try hooking up a 9v to the pump. If that works, then you know it's bad wiring.
  24. shineynitelite
    what good is your 30 day warrenty? everything?
  25. Dynapar
    hey brian,
    my parents are going to be bringing in there 03 silver legacy wagon for some work tommorow AM. i told them to ask for you. just thought i would let ya know, sorry for the last minute update.
  26. Dynapar
    Well, i am wondering if i could get a quote for some repairs on my car. looking towards head gaskets, rear main seal, and rear access cover. 1995 2.2l Auto Impreza LX
  27. John16V
    Have these in stock? How much (total) with our discount?
    Bumper Vents for the 99-01RS
    57744FA200
    [FONT=&quot]57744FA210
    [/FONT]Thanks,
    John
    [FONT=&quot]
    [/FONT]
  28. driftin240
    Head Gaskets? On a 2.2L....are you new? They very rarely go, and why would yours go if AWDl's haven't gone yet. Stop smokin that wacky stuff, and just fix your oil leaks. I would believe valve cover gaskets, a rear access cover and a rear main seal....but not the head gaskets. More than likely an oil pump re-seal, and a cam seal or two....along with both of the cam o-rings.
  29. driftin240
    Those aren't in stock, but I can get them for you. $52.33 for both w/tax.
  30. Chux
    old skool key blanks with light:
    57430AA130
    can you get them? if so, what's the cost?
  31. AWDimprezaL
    13.56 before tax, not in stock, available though
    phi11 likes this.
  32. zyklon
    zyklon Well-Known Member
    Sent this in a PM to AWDimprezaL then found this thread so I'll repost...
    was wondering if you had these mats:
    https://www.subarugenuineparts.com/p...roducts_id=133
    ..or really anything winter-suited for my '06 WRX TR, if these are an old part or something.
    Also, is there a trunk mat for the sedan variant? on subarugenuineparts I only see one for the wagon. Something sticky to keep stuff from flying around on that carpet.
  33. webcrawlr
    webcrawlr Well-Known Member
    Yes, they carry the all weather floor mats.
    There's no US sedan trunk mat. You can order the JDM version but it's spendy. You can also but the wagon mat back there but there will be a gap of about an inch all the way around.
  34. driftin240
    Winter mats for the passenger compartment are $49.95, and the Cargo mats for wagons are $70.00
  35. k_thaosta
    k_thaosta Well-Known Member
    Are the power steering pumps the same for all Subarus? Which one would fit the wrx/sti?
  36. Chux
    maybe I'll order a key blank after the holidays...
    BUT, I need a fuel pump, like yesterday.
    42021GA290
  37. driftin240
    No they are not all the same. The one for a WRX/STi, fits the WRX or STi.
  38. driftin240
    Don't have one in stock....sorry. $255.56 w/tax.
  39. Chux
    man, I'll take the napa version for half that, thank you...
  40. sapalas
    I was wondering what is the price on a idle air control gasket, I'm thinking about cleaning it good and want to check and probably replace the gasket. 04 WRX Wagon
  41. driftin240
    I think they are somewhere along the lines of $7.00, but i'll get you the real price on tuesday.
  42. Underhill
    Underhill New Member
    Brian, Ive been looking at various threads about the rear struts in the Sti (mine is an 04) got it used out at BP. The rear struts clunk, and bounce alot, at times it doesn't feel safe. The car has 67k on it right now, is there any recall on the struts that I havn't gotten taken care of, or could they be covered under warrenty? if it's the struts that is. Also the shifter rattles some, Ive had people suggesting replacing bushings, just wondering if any of the techs have any idea, I got the car at the end of Oct. (Silver 04 Sti)
  43. driftin240
    There is no recall for the STi struts or mounts...nor is there a TSB about it. I know from prior experience that it's the tops themselves that make noise, but it won't fix it just to throw tops in it. Normally you have to replace both the tops and the struts. STi struts are very expensive and I wouldn't recommend you buy them, unless you want the same problems again. Buy some KYB AGX's, and some new mounts.
    It's not really a warranty issue unless your under 3/36... Or you have some sort of extended warranty.
    As far as the shifter bushings go, I haven't heard any complaints about the Kartboy one's.
  44. hakstern
    hakstern Member
    I need some rubber mats, I was wondering if you have them in STOCK now..been awhile. If you don't how much shipped to 56201 (Willmar). Or if you can get it by saturday :biggrin: I was pick it up.
  45. AWDimprezaL
    all weather mats in stock $39.96 before tax
    phi11 likes this.
