Minnetonka Subaru- 10% Labor and 20% Parts Discount
Discussion in 'Vendor Announcements/Sales/Discounts' started by driftin240, Nov 21, 2005.
  1. Bielke55
    Yea did we pick a day? wed or thurs?
  2. carl
    it's both days. i'd like to get the clip either today or tomorrow so let me know if you can make it wed
  3. Bielke55
    I can make it wed for sure
  4. Scuba Steve
    Brian, is my touch up paint in? If so, can you please bring that with? I'll give ya a beer on Friday for the troubles:cool:
  5. carl
    excellent, please bring that clip with. we'll be starting around 6:30
  6. 02blubru
    how much for a bike rack for the roof of my car? one that carries 2 bikes.... What all would I need? I have the factory cross bars.
  7. Bielke55
    Want one for your trailer hitch?
    Roof mounted =$239.96 - In stock
    Hitch Mounted = $183.96 - No Stock
  8. 02blubru
    can I come check out the roof mounted one???
  9. G_2.5rs
    G_2.5rs Well-Known Member
    how much for 99 impreza rs front 02 sensor?
  10. AWDimprezaL
    Three different options, whats the last 8 of the vin.
    phi11 likes this.
  11. Paul Revere
    Scared to drive out to tonka fella, gonna take the shorter trip to Bloomington ... sorry but it makes more sense for this item.
  12. AWDimprezaL
    alright.
    phi11 likes this.
  13. Paul Revere
    Got it taken care of and they hooked me up with a discount :) Good thing I didn't go to tonka she was getting hotttttt :eek3:
  14. G_2.5rs
    it is.....XG403252
  15. AWDimprezaL
    $111.96 in stock
    phi11 likes this.
  16. bobafett04wrx
    bobafett04wrx New Member
    Just out of curiosity can you guys get brembo blank rotors for 04 wrx? And what would they cost?
  17. qstarin
    qstarin Well-Known Member
    Sail panels - the little triangular plastic pieces on the door that snap into the mirror assembly.
    How much? Would you have to order them? For my 01 RS.
  18. AWDimprezaL
    $5.02 EA would have to order.
    phi11 likes this.
  19. qstarin
    So much cheaper than a-pillars. :) Now where's my drill. He he.
    Do you guys still have my CC info, or do you need it again? I'll take one L/R pair for now.
  20. pbedroske
    pbedroske Well-Known Member
    for 2004 wrx
    Air Conditioning line - 73422FE011
    fuel filter
    pcv valve
    intercooler/bpv gasket
    fuel line parts 17544AA134 and 807707140
    engine block heater A0910AS100
  21. pksublime
    pksublime Well-Known Member
    Okay, I need to do my timing belt on Nat's '02 2.5RS.
    Would you please breakdown all the parts I need (add anything you think I'll need)
  22. qstarin
    If you guys haven't ordered this yet, up it to 2 pair. Need cc info?
  23. AWDimprezaL
    Done, should be here monday.
    phi11 likes this.
  24. qstarin
  25. pksublime
    Erik (or insert other 'tonka guy), do I have to make a list or will you help me out with this?
  26. Bielke55
    Once you remember my name... I will help
  27. Shibbs
    HINT: Its in his screenname.
  28. Bielke55
    Air Conditioning line = $184.36 N/S
    fuel filter = $21.26 I/S
    pcv valve = Dont believe you replace them... $13.46 I/S
    intercooler/bpv gasket = $5.02 I/S
    fuel line parts 17544AA134 =$52.66 I/S
    and 807707140 = $11.90 I/S
    engine block heater A0910AS100 = $31.96 I/S
  29. pksublime
    Brian "Bilknutz" Bielke
  30. Bielke55
    Thank you
    Timing belt = $71.96
    Tensioner = $119.96
    Idler Pulley 1 = $33.48
    Idler Pulley 2 = $59.96
    Cogged Pulley = $65.46
    Water Pump = $79.96
    W/P Gasket = $3.18
    T-stat = $12.76
    T-stat Gasket = $2.74
    Timing cover gasket (lower) = $5.86
    All in stock
  31. pbedroske
    I'll take these. I'm hoping to find a good used A/C line from someone. I have a few leads on that.
    Are you able to ship to 55906? or do I have to make a special trip up there? If I have to go up, what are your hours?
    thanks,
    Pat
  32. pksublime
    With a timing belt change are the crank and cam seals usually needed or not? If so price please.
    Also, looked under the car last night and saw a BIG dent/bend in the oil pan. Probably should replace it and gasket to be safe right?
  33. Bielke55
    You would see oil loss or burning if you need cam seals and crank seals. While doing the Timing belt you can look and be sure.
    Cam seals = $6.42 each x2
    Crank seal = $6.86
    Oil Pump Oring = $1.62
    Oil Pan = $111.38 - No gasket just RTV Silcone
  34. Bielke55
    If you PM me with your info we can ship parts out for cheap.
  35. WRXEcho
    WRXEcho Well-Known Member
    How much for a 02 wagon front-pass-side tie rod?
    Danke,
    - Justin K.
  36. AWDimprezaL
    $43.96
    phi11 likes this.
  37. WRXEcho
    In stock? Other side same price? Are they complete (w/boot, mine ripped)?
    Thanks,
    - Justin K.
  38. pbedroske
    Sweet Fast shipping!!! Thanks!
    -Pat
  39. AWDimprezaL
    In stock, same per side. No boot included, $16.22 for das boot, not in stock.
    phi11 likes this.
  40. WRXEcho
    If you could order a couple boots that would be sweet :)
    Thanks,
    - Justin K.
  41. carl
    can you guys order me the little white plastic headlight bracket (bielke knows which one) for an 04 sti.
  42. Bielke55
    In stock!
  43. Goalie
    Goalie MNSubaru Goaltender
    How much for a driver side 04-05 Sti front bumper splitter?
  44. Who dat ninja
    Who dat ninja Well-Known Member
    Can I get price/availability on the following parts for a '99 Legacy L wagon please:
    Cargo area tray (I think pn# J5010AS200)
    Bumper protector cover (goes on top of rear bumper)
    Bug Deflector for hood
    Also, do you take subie bucks to pay for tires? (Do you guys sell tires?)
    Thanks
  45. Dynapar
    I am looking for price and availability on the following:
    EJ22T Complete Shortblock Gasket Set
    EJ22T Block Case Bolts (hold the halves together)
    97-99 EJ22E Headgaskets
    2.0L WRX Water pump
    2.0L WRX Timing Belt
    EJ20 valve cover seals
    SPT Intake for 02/03 WRX
    I will probably need more stuff when I think of it.
